High pressure oil pump - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-06-2009, 02:31 PM Thread Starter
Exclamation High pressure oil pump
I have a 2001 pwrstrk and i have a leaking hpop i need help trying to figure out how to get one. Can i put one out of a international 7.3 out of a medium duty truck? Please help me!!!
2001powerstroke4X4 is offline
post #2 of 4 Old 03-06-2009, 07:25 PM
guzzle's Avatar
Why not just fix the leak?
02 F350 4x4 SRW EC LB Lariat
guzzle is offline
post #3 of 4 Old 03-06-2009, 07:28 PM
You might be able to fix it depending on where the leak is. If not, then the Medium Duty one would work, I'm pretty sure. I have looked at the one on my international wheelchair bus, and it looks the same.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
post #4 of 4 Old 03-06-2009, 07:33 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 493 Post(s)
Is it leaking at the gasket where it mounts to the engine just replace the eleven dollar gasket make sure you fill the reservoir after you replace the gasket its not a hard job
@loxdce
LoxDiesel is offline
