hard to start HELP - Ford Powerstroke Diesel Forum
Old 03-04-2009, 03:09 PM
hard to start HELP
2000 e450 with 7.3 has trouble starting, in morning , just when colder out, turns over excellent
Old 03-04-2009, 03:15 PM
If it aint a CAT itsa DOG
check the glow plug relay.
Old 03-04-2009, 03:27 PM
where is the glow plug relay located on the e450?
will the relay being bad cause a hard start when cold? thanks
Old 03-04-2009, 03:30 PM
If the relay is bad then it won't allow the glow plugs to operate properly resulting in your hard start. I believe the relay is located by the passenger side valve cover. It looks like a starter relay. I will try to find a pic for you.
Old 03-04-2009, 03:31 PM
Ok check this link. It will show you the locations of both the air intake heater and the glow plug relay. Glow Plug / AIH Relay locations
Old 03-04-2009, 03:46 PM
thanks will check out
