Help: Engine Knock w/ Greyish White Smoke - Ford Powerstroke Diesel Forum
Old 03-01-2009, 12:54 PM
I have an early 99 its makin a knocking noise with a constant flow of white smoke with a really destinctive smell to it. Its not burning any oil i have heard so many different things would like to ge it narrowed down I was in cruise control when it happened the truck is running a bully dog power pup 4" straight pipe its also a 6 speed its not the turbo already had it off and checked.
Any help would be greatful b/c I am boggled.
Old 03-01-2009, 01:01 PM
Are those the only mods your running?
Old 03-01-2009, 01:05 PM
Yes thats the only mods truck has 35" tires and 220000 miles
Old 03-01-2009, 01:21 PM
I have heard bad injector or bent valve a little of everything really!
Old 03-01-2009, 01:30 PM
You need to do some diagnostics like check for codes, CC test, balance test, maybe even compression test. You said smoke smell was distinctive, is it fuel? I would assume so. Are you low on power? Does the engine have a miss to it?
Old 03-01-2009, 01:33 PM
Yes it has lost power and sounds to have a miss to it!
Old 03-01-2009, 01:34 PM
Cynic
Without this information, everything is just a guess.
Check fuel pressure also.
Old 03-01-2009, 01:39 PM
Also loss of power and sounds to have a slight miss! When cranking over it seems to hit then crank hit then crank but it will start up and when u first start it it wont knock or smoke then after about 30 sec or so it starts knockin and smokin! Its definately fuel
Old 03-01-2009, 01:59 PM
my programmer says it not throwing any codes
Old 03-02-2009, 11:46 AM
No one else has anything on this? I am thinking injector or O-ring
