won't warm up!!! - Ford Powerstroke Diesel Forum
Old 02-28-2009, 02:34 PM
won't warm up!!!
Well my temp. gause only goes about 3/8 way up and takes a lot longer to get to even that. Used to ride about 1/2. I'm thinking thermostat stuck open, any other opinions? How likely is it that the temp. gauge may not be working correctly, all gauges are OEM in the dash.
Old 03-01-2009, 06:40 AM
anyone? I'm gonna put in a t-stat in a couple days...I think a 195* comes factory, thermostat info says a 203* is better...what do ya'll think.
Old 03-01-2009, 06:48 AM
had a similar problem with mine years ago, replace the stat and the engine warmed up better. i would personally go with whatever is stock.
Old 03-01-2009, 06:57 AM
temp gauge should be working right is the heater blowing real hot or no if it aint i would go with thermostat
Old 03-01-2009, 01:44 PM
heater doesn't really blow hot unless on the interstate and running about 2,000 rpm for a bit...guess I'll be putting in a thermostat.
