need help with motor - Ford Powerstroke Diesel Forum
Old 02-26-2009, 03:16 PM
I have a 99 that ran one day and not the next. I have tried all types of starting aids. I have a matco proscanner, don't know much about it but have checked several things that others have told me to check. I have put a pressure gauge on the high pressure oil rail and it shows 2500 to 3000 psi. I have changed the cam sensor. I have changed high pressure oil sensor. I have checked fuel pump and took fuel lines loose from fuel filter base and checked fuel flow. I dont have any way of checking fuel pressure yet, but it does seem to have lots of fuel flow. Scanner says there are no codes. I checked wiring harness going to valve covers both sides, did the buzz test with scanner. it came back no problem. Tried most other simple common diesel troubleshooting things. I can't figure out why it will not start with the starting aids. A respectable diesel mechanic suggested that the injectors were bad. Could this be a symptom of my problems, if so why wouldn't it start with starting fluid? Could all the injectors go bad at once? Thanks for the help.
Old 02-26-2009, 03:22 PM
If it aint a CAT itsa DOG
First welcome to the org. 2nd DO NOT USE starting fluid!!!!! You can cause serious engine damage because of intake heaters and the glow plugs. Starting fluid is meant for engines with no glow plugs. Your turbo and heads will thank you. Any other symptoms that might help us out? Was it running weird before, any smoke, loss of power, etc...? Hows your oil level?
Old 02-26-2009, 04:25 PM
thanks for the help.there has not been any problems.this is a stock truck no mods.no adnormal smoke before now little to no white/gray smoke while craking over.oil level is fine HPOP res and rails are full.all mant has been done.checked for fuel leaks and air in fuel system nothing found.
Old 02-26-2009, 05:40 PM
what should the HPO psi be at when cranking with a gauge on the oil rail
Old 02-26-2009, 05:45 PM
i'm not honestly sure of the psi, check and see if the ICP sensor has oil in it. Also is your tach moving when you are cranking on it?
Old 02-26-2009, 06:02 PM
i have a new ICPS and the plug is clean.i'll check the tach but the scanner reads 132 rpms when cranking is the same.
Old 02-27-2009, 03:41 AM
Send a message via Yahoo to Big_Stroker
how about the #30 fuse have you checked that yet? dont over look the little stuff here. Check all your fuses but the #30 is the most common
Old 02-27-2009, 05:37 AM
ya checked all of that first and the fuel reset
Old 02-27-2009, 05:48 AM
do you have any smoke at all when trying to start it,also do you have your wait to start light?
Old 02-27-2009, 09:21 AM
little to no white/gray smoke.yes light is working.everthing with glow plugs working up to the valve covers.i see alot about HPO having to be around 500 psi at idle. i have about 2500/2800psi at cranking over is this good or bad or a sign of something .the IPR reads 38% while cranking
