"Do Not Remove plug" - Ford Powerstroke Diesel Forum
Old 02-23-2009, 04:07 PM
I removed the do not remove plug and replaced the O-ring as well as the rest, will not start now....what did I do wrong?
Old 02-23-2009, 04:19 PM
I can't help, but if you go here...
Replacement O-rings for Diesel Engines
there is intructions on the "right" way to do it (according to those guys anyway...I have no idea)if you HAVE to do it for one reason or another. Personally, I might give it a try, but only AFTER I have resigned to buying a new pump, just in case......
-Aaron
Old 02-23-2009, 04:20 PM
Chug-a-lug!!!
YOU REMOVED THE DO NOT REMOVE PLUG!!!!!!!! HOLY CRAP MAN, WHAT WERE YOU THINKING!!!!!!!
Actually I have no idea what you're talking about. Here's a free
My dad did that and after fighting and battleing he ended up having to buy a new one!
Sorry dude!
Old 02-23-2009, 04:21 PM
Send a message via Yahoo to harleyultra1969
LMAO - Is that kinda like removing the "Do not remove" tag on a mattress?
Old 02-24-2009, 07:29 AM
Thats Mr. Oil Leak.....
are you talking about the "non serviceable" plug on the HPOP? If you removed it without knowing you probably lost the check ball. If you cannot find that check ball and replace it in the pump you will have to buy a new pump.
Old 02-24-2009, 08:00 AM
is there a fine for that? Possible prison time?
Old 02-24-2009, 08:09 AM
Scuffy said he learned the hard way. He had to replace the pump I figure if he cant fix it it cant be fixed.
Old 02-24-2009, 08:13 AM
I believe there is a family guy clip that fits this bill...
Old 02-24-2009, 08:28 AM
ADMIN AND TECH
if you removed the do not remove plug on the high pressure pump, you might as well get you a new pump , for one ive have successfully fixed a couple by doing that , did it last NO , it will be back loose again, the problem is the plug when works lose damages the threads of the pump housing , you might as well by a pump
