Injector Tick or Something else?
I recently purchased a 2002 f350 7.3L. It seemed that it blew smoke on startup (it's cold here, but does blow alot of smoke) until it warmed up for a few minutes, and has an loud anyoing ticking (almost like a rod knock, but not quite). The motor also had a miss in it a little.
I failed a contribution test on #8 cyclinder, so I replaced the injector yesterday. The engine sounds smoother, and has plenty of power. Runs great, still blows smoke on startup. But this ticking noise has to give. Can injector cackle be this loud? It starts up fine, after 3 minutes the cackle begins. Is there anything I can do to help make ti quiter? Thank you. |
mine does something similar, i can hear it really loud in the cab, course my 7.3 is quite a bit older than urs bein a 96
I'll be real happy to hear the responses to this thread also. I have 1996 7.3 with the same annoying ticking sound..most noticeable when i take my foot of the accelerator...steve
yep just at idle.
Did the noise go away with any one cylinder off-line during the contribution test? If so - you may have a cracked tip on that injector - if not - you could have a bent push-rod. Both are fairly common causes of the noise you describe.
how much does a bent pushrod cost to fix? and idk if the op still is subscribed to this thread cuz its over a year old
RockAuto has them for $3.31 - the valve cover gasket is re-usable so if you figure out which one is bent, it should cost you $3.31 and about an hour of your time swapping it out. SEALED POWER Part # RP3345
Partially true - The AE was introduced in 2001-2002 production run as the long lead injector for cylinder 8, while 1-7 were AD injectors. AD and AE are split shot injectors - AA's are single shot. You couldn't mix AA and AE in any way, shape, or form. |
They require code AE injectors in the 94-98 PSD's on cylinder 8. its a common misconception and idk if they are split shot or not, i dont think they are.
