nobody??? should i take that as it sounds normal?
Sounds ok. Is that cold or up to temp?
Sounds fairly normal. But with that low compression you do have an issue
that was driving the piss out of it after replacing the HPOP o-rings, so not fully up to temp, but close.
Have you checked the per/del numbers? I thought I heard a faint tick when you walked around to the front of the truck but nothing significant. I can't tell if its a ticking or fuel knock, I'd be concerned about the low cylinder though.
1. what are the per/del numbers
and 2. what would check them, a scanner, or the AE system? |
2. I am not familiar with the Auto Enginuity system but I know a good scantool will show them while reading the data stream info. |
broken TC i had a 99 7.3 psd did the same thing whent to ford they told me what it was did not belive it but it was the TC!!!!
