injector code P0296 - Ford Powerstroke Diesel Forum
Old 02-18-2009, 02:14 PM
If it aint a CAT itsa DOG
injector code P0269
I got my auto enginuity today and i ran a CC test and it said that my cylinder 3 had an injector circuit contribution/ balance fault. I am assuming this is got to be part of why its running rough at times. Anyone know what would be causing this code? Bad injector or under valve cover harness? Any help would be great guys, so that i can acutally fix this problem once and for all.
Old 02-18-2009, 02:31 PM
Send a message via AIM to harrys91rs
If you go to the Live Data Grid tab and select the PerDel for each cylinder it will give you the actual numbers they are. A buzz test should tell you if the harness is good or not. P0296, i'm getting cylinder 12, lol. I think you mean p0269.
Old 02-18-2009, 02:32 PM
Oops, i bet thats what i meant. I ran a buzz test and all came back good. I am still learning on this new thing.
Old 02-18-2009, 03:12 PM
If you don't have any uvch codes, and it passed buzz test its probably ok. Do you have the grey recall cps? The grey one can cause bad readings on 3 and 8 for some reason. Once you get the Change Rotational Velocity (perdel) numbers you can see how bad that cylinder is, if its borderline or not.
Old 02-18-2009, 03:48 PM
what else would cause that code then? I have the dark blue IH CPS.
Old 02-18-2009, 04:52 PM
