problems starting - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-17-2009, 07:38 PM Thread Starter
007.3stroker's Avatar
problems starting
2000 f250 173000 miles whene i start it on cold mornings it will start and then die start and die tell it gets to operating temp it will run for about 10 min each time but seems like the fule runs out
007.3stroker is offline
post #2 of 7 Old 02-17-2009, 07:40 PM
KVFD
redstroker_2002's Avatar
whens the last time you changed the fuel filter?
-Josh
2008 2500 LMM- Deleted, Blocked, Fueled, & Tuned by:
redstroker_2002 is offline
post #3 of 7 Old 02-17-2009, 07:43 PM Thread Starter
i just changed it and it still dose it
post #4 of 7 Old 02-17-2009, 07:55 PM
bad_blue_oval's Avatar
when it starts and runs, how does it run? Lopey, Normal, lots of smoke??
02 F250
Full force stage 1's
FBD 5"strait pipe
DP Tuner
72 F100 4x4
bad_blue_oval is offline
post #5 of 7 Old 02-17-2009, 08:01 PM Thread Starter
lopey no smoke but if you bring it up to 1500 rpms it sounds fine but then acts like it runs out of fule
post #6 of 7 Old 02-19-2009, 05:06 PM
have you figured out your problem yet?
02 F250
FBD 5"strait pipe
DP Tuner
72 F100 4x4
post #7 of 7 Old 02-21-2009, 06:03 AM
I would hook up a fuel pressure gauge and monitor fuel pressure when it stalls. Could be lazy lift pump or restriction in tank. How does it run once warmed up?
Russ
Late '99 F-350 7.3l 6sp 2wd aftermarket dually kit 255,000mi
STOCK
Deeslfxr is offline
