Oil problem? - Ford Powerstroke Diesel Forum
Old 02-17-2009, 01:46 PM
Oil problem?
We have a 2002 F-250 7.3L. I have a 400 mile trip tomorrow with some horses.
I went to check the oil tonight and it did not read,and I checked many times after cooling for an hour and after driving immediately. The only time it reads is after it is running. I am thinking since it holds so much oil the oil gauge and light hasn't been tripped yet. The things sounds fine,but it does a have a small leak some where. The oil isn't even registering on the stick. I am thinking the gauges and everything are working fine and it might be 2-4 quarts low. My question is does the stick go dry for some time before the alarms sound. I just need to know if I need to add oil or not,but I am thinking so. 145,000:miles
Old 02-17-2009, 01:50 PM
ADMIN AND TECH
if the oil isnt that old just top it off , and keep an eye on it , if its time for an oil change , go ahead and change it
Old 02-17-2009, 01:51 PM
If it were my truck I would add
Old 02-17-2009, 01:55 PM
I guess ya"ll are saying the gauges don't work until you are really low. I will just top it off then. It has eight thousand miles since last oil change,but we just have not changed it yet. It, is not my decision when it is changed on this truck.
Old 02-17-2009, 02:33 PM
I just wonder if this is normal. I also wonder what is leaking.
Old 02-17-2009, 07:09 PM
Well it was six quarts low. I think the sensors or something is messed up. How do I check it?
