cold buzz test - Ford Powerstroke Diesel Forum
Old 02-15-2009, 10:52 AM
cold buzz test
So I did a buzz test early in the morning, before a warm engine, and it sounds like 5 and 6 are weak. Warm up the engine and they all sound the same. my problem is good boost, but lower power and rough acceleration. cruising at 60, there is a loud humming from the motor and a vibration from the motor. any ideas? should i pull valve covers and unplug those injectors to see if it changes the way the engine idles?
Old 02-15-2009, 11:20 AM
duct tape & zip ties
Did you do a cylinder contribution test as well.
The buzz test tells you if the injectors are working properly.
Old 02-15-2009, 11:58 AM
How do you do the buzz test?
Old 02-15-2009, 12:01 PM
You need a diagnostic computer, or a lap top that has Auto Enginuity on it. The buzz test is a KOEO diagnostic test. A cylinder contribution test is a KOER diagnostic test.
KOEO= Key On Engine Off
KOER= Key on Engine Running
Old 02-15-2009, 02:08 PM
Interesting, theres a Snap On diagnostics computer at my work for cars. will that work on my truck or do i need a different one for diesels?
Sorry not trying to HiJack, its just i asked this in another thread but it got closed so i figured you did it so youd know.
Old 02-15-2009, 02:17 PM
I can not say for sure or not if the Snap on tool will do these tests or not. Because I do not know which Snap On tool you have at work.
Old 02-15-2009, 02:50 PM
Oh ok lol well illl have to give it a look at.
Old 02-15-2009, 02:58 PM
yeah, i did a cylinder contribution test and everything checked out.
