Throttle not responding
When I turned my truck on this morning, it would turn over, but little to no throttle response. The truck would idle at about 800 rpm. When I pushed the throttle, it would go up to about 1100 max. It's been very cold here (about 6 deg. F). Could this be due to the cold (maybe the oil's too thick)? Or could this be something else. Would it be a good idea to plug the block heater in? Thanks for your help.
Did the throttle respond after the engine warmed up a little I bet it did. That is normal, it is part of the cold start on the truck. Yes it would be a good idea to plug it in when it is that cold out.
Thanks!
Yes, it did. It has never been this cold here before, so this never happened before. Thanks!
ya that is what happens when it's cold. let her run a while or plug it in. here in michigan (still warm and rain). my truck does it all the time. try to go to a thinner oil, if u can find some. i cannot seem to find anything lower than 15-40.
