7.3 P1316 DTC
Fellas,
I have a 2001 F350 that I'm workin on and it started out with a p1316 Ignition Diagnostic monitor code is detected code. it would randomly just kinda studder and stuff. well yesterday it finally got to where it wouldnt run at all. so i Scanned it today and its got 3 P0605 powertrain control module read only memory failure, and P1294 High side open bank 2, P1670which is a no EF signal code for the idm to PCM. with what experience I have i think its a PCM failure plus from what i have read but I want to make sure before i go and replace a 400 dollar PCM. Any input would be great. Thanks Drew |
remove the valve covers and reconnect the short harness on both sides , and clear the codes
if your pcm is gone then when you turn the truck on to see the waite to start light it won't be there it never comes on if the pcm is out hope this helps
scuffy,
I did like you said and unhooked the wire harness from under the valve cover. that got rid of the p1294 now the only code im dealing with is the p0605. and the truck will still not start. from what i have read on that code is that it either a pcm failure or a pcm with the wrong flash this truck has not been flashed in like 5 years so i dont see it having the wrong flash. with that said if the PCM is out like that will it not allow the truck to run??? Thanks fellas, Drew |
does the wait to start light come on
Yes it comes on. this thing is really throwing me through a loop.
does your scanner monitor data
like the data stream
yes , im curious if the scanner you have can monitor data just to see , if it will pcm may not be your problem, id like to monitor a few things
what would you like me to monitor
