Fuel Pump - Ford Powerstroke Diesel Forum
Old 02-07-2009, 04:12 PM
I need money...
Fuel Pump
So...My stock fuel pump positive terminal broke.Please dont ask. Im just wondering what is a good aftermarket replacement for the stock one? One that would be good for stock and bigger injectors soon. More power is on the way,and I am running an air dog system. Any help would be great.
Old 02-09-2009, 09:21 AM
The Screwy HEUI
Isn't the AirDog system an upgraded fuel pump like the FASS with the fuel filter & fuel/air separator? Or do you have something else? SCUFFY828 has a super-modified PSD, & uses the FASS fuel system. Although, I remember him saying his system was leaking. Not sure.....
Old 02-11-2009, 10:27 AM
I need money...
The Air Dog is just mainly a fuel preporator. It feeds the stock fuel pump clean fuel, minus the air bubbles. It also had a 2 micron filter! My engine sounds alot quieter and runs more smoothly with it. I hear the Walbro is a good stock replacement. Any insight?
Old 02-11-2009, 10:49 AM
Ole White
If you want a drop in stock replacement that flows much more than stock go with a Walbro GSL-392 you can get it from Summit Racing for around 125 bucks if I remember correctly and it installs just like the stocker only thing you have to do is on the feed line coming from the tank is cut the quick connect off and slide the bare hose on the hose barb and use a hose clamp and your good to go
many use this setup and its a good and cheap alternative
Old 02-11-2009, 11:36 AM
The Screwy HEUI
Nice! I'll have to look into that too! Thanks, bigwhite!
Old 02-11-2009, 06:20 PM
I need money...
Thanks!! What about a pressure regulator after the pump? What setup do most use?
Old 02-12-2009, 03:25 AM
Ole White
No problem man
all I changed is the pump for now but will soon make my own Regulated Return or buy ITP's RR with fuel bowl delete kit
Old 02-12-2009, 07:30 AM
I need money...
No problem man
Got it! How does the truck run with the Walbro? Noisy? Any difference? I always thought you needed a regulator after the pump or does the stock FPR bring the pressure down?
