Starting problems - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-07-2009, 11:31 AM Thread Starter
Once you go black......
CanadianDiesel's Avatar
Send a message via MSN to CanadianDiesel
Unhappy Starting problems
It first did this awhile back, I had not plugged it in but it was only 15* or so...didn't think much of it.
So when I go to start it up, like this morning (sat for 6 hours, 5* outside), I double cycle it and it cranks great, fires and then dies right after. Crank again, same thing. If I were to keep cranking it does nothing. After about 10 tries it roars to life
It did it today when I got out of class. It was not too cold today...any ideas, anybody?
Then & Now
Matt
'99 F-350 4x4 7.3L
6637, 4", chip; far too many upgrades to list.
Coming soon: Rigid Industries Lighting, Nav, On-Board Air.
Latest mods: Line-X, '08 Black Leather Captain Seats (Lariat), Trans, EGT and Turbo Gauges; TS chip, Chrome Delete.
02 VW Jetta TDI - 40mpg
CanadianDiesel is offline
post #2 of 11 Old 02-07-2009, 02:42 PM
RadarRider's Avatar
Can you scan for codes? This could be a couple of different things. Possible 1+ glow plugs dead.
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #3 of 11 Old 02-07-2009, 05:42 PM Thread Starter
I don't have a scanner...if it persists she'll go into the dealer.. Starting up tonight it seemed fine. Could this be water in the fuel?
Then & Now
Matt
'99 F-350 4x4 7.3L
post #4 of 11 Old 02-07-2009, 06:04 PM
Cory S's Avatar
sounds like bad fuel or something have you replaced the fuel filter?
Vegistrokin
2000 XC 4x4
-CORY
Orlando, FL
Cory S is offline
post #5 of 11 Old 02-07-2009, 06:24 PM
RadarRider's Avatar
Make sure you drain the bowl too, when you replace the filter.
post #6 of 11 Old 02-07-2009, 06:57 PM Thread Starter
Thanks for the help guys Will look into it.
Then & Now
Matt
'99 F-350 4x4 7.3L
post #7 of 11 Old 03-20-2009, 09:40 AM Thread Starter
Guys I have a question...is oil in the intake tube a good or bad thing? Still getting to know the 7.3/
It won't start this morning, its around 25* out, not cold at all... I have the weekend off I'm thinking of buying a few things and doing the work myself.
Any suggestions...
Then & Now
Matt
'99 F-350 4x4 7.3L
post #8 of 11 Old 03-20-2009, 07:18 PM
RadarRider's Avatar
Any suggestions...
The oil in your intake is typical. The only way to resolve that is the CCV mod. Talk to Raul or NCHornet about it. NCH designed it, Raul sells it. As far as 25*, you're talking Celsius, right?(damn Canadiansj/k, I'm of French-Canadian decent). If it's that warm, I'm thinking you're having problems with your GPs or GPR. There's an article in the 7.3 tech files that tells you how to test both. If your GPR crapped out on you, check out the Stancor unit if you replace it. It's the best money can buy & it's much beefier than anything else you'll find on the market.
post #9 of 11 Old 03-20-2009, 07:40 PM Thread Starter
Alright, that's good about the oil
Haha no that's 25* Fahrenheit! I always convert it for you guys lol
Thanks for the tip on the glow plugs and GPR...others seem to think it's that too. Thing is, even when its 32* (0*C lol) it may not start, but it's a guaranteed start when the block heater is going.
My old man has been telling me to unplug it though...apparently the hydro bill is higher than usual
Now that summer's on our doorstep who knows if I'll get around to a GP job myself. Last summer this truck gave me absolutely no problems. It seems to prefer the warmer weather
Then & Now
Matt
'99 F-350 4x4 7.3L
post #10 of 11 Old 03-20-2009, 08:16 PM
RadarRider's Avatar
Yeah, it's just one of those things with diesels: glow plugs come, glow plugs go. I'm thinking mine's coming up for a GP job, too. With a good scan tool that does functional tests, most of them have a glow plug test where you don't even have to take anything apart, you can do it from the comfort of your own cab. I hear you too on the elec bill....try having to plug 2 trucks in during winter months! Good luck with everything, you'll get 'er figured out!
