01 7.3 codes and fuel problem - Ford Powerstroke Diesel Forum
Old 02-06-2009, 10:46 PM
i have been having a big problem with my 01 7.3 f250
it is throwing a2 codes
high/low injectore fuel pressure and
fuel injection system fault
it will not start by itself or with starting fluid
i replaced the
icp
high pressure fuel pump
cps
new rings on all the injectors
fuel pump relay
when i replaced the icp the truck started no starting fluid and rran at idol then cut out and trhew codes again
when i can start it on eether i have to hold the gas and keep it at about 2k to keep it running then it shuts off
Any ideas i dont know what to think any more ?
Old 02-06-2009, 10:55 PM
scuffs *****
Send a message via AIM to Tyler
i replaced the
icp
cps
fuel pump relay
You killed it with ether.
Old 02-06-2009, 10:56 PM
what
i used starting fluid
i dont get it ?
Old 02-06-2009, 10:57 PM
scuffs *****
i dont get it ?
Ether = BAAAAD for these motors. Lots of people have wasted a good motor with it.
Old 02-06-2009, 11:01 PM
what gets wrecked?
what does it actuallty hurt?
besides your glow plugs?>
Old 02-06-2009, 11:04 PM
scuffs *****
The glo plugs can ignite the ether prematurely and can destroy the valve cover, making it leak, and I'm pretty sure its really hot on the pistons.
Old 02-07-2009, 08:01 AM
I doubt you killed it with ether, yet. Although ether is a no-no for any diesel with glow plugs or intake air heater, I don't think you did any significant damage unless it preignited hard enough to hurt a rod or piston. Which codes are you getting exactly? Have you checked fuel press. and HPOP press.?
Old 02-07-2009, 08:04 AM
dont worry about the ether im sure its fine. next. if you are in a pinch and must use it. unplug the GPR, so it does not turn on the glow plugs.
It sounds to me like your IPR valve is messed up. Its one of the only things you didnt cover in your list. it is located under the fuel bowl down towards the left. i changed it in 5 minutes on my first time.
Old 02-07-2009, 08:31 AM
scuffs *****
cchase, what haven't you replaced on that thing?
Old 02-07-2009, 08:32 AM
the driver.
