Help identifying oil leak from picture - Ford Powerstroke Diesel Forum
Old 02-06-2009, 05:57 PM
New leak - front driver side adjacent to oil pan - dripping from a bolt. Don't know what the equipment is it's dripping from. Can you help?
Old 02-06-2009, 06:11 PM
My buddy says rear Rear Main.
Old 02-07-2009, 08:26 AM
From the front of the motor? I don't think so. The bolt is holding a ground cable to the block. I can't see where I want, but it's coming from somewhere above there. Possibly from front cover where it seals to the block or pan gasket in the corner. Hard to tell. More pics will help.
Old 02-07-2009, 08:53 AM
leak
there is a small plug there that could be leaking.or hpop gasket / O-rings leaking and going down the fuel lines and ending up on the ground bolt.
fix take off ground and clean up the area and you should find it.
Old 02-07-2009, 08:55 AM
def not rear main
Old 02-07-2009, 09:25 AM
highly doubt full. very very rare. I talked to a tech that has never seen one in 10 years.
Old 02-07-2009, 04:33 PM
Couple more shots.......
I can't see anything from above. It has however been leaking for a while from the looks of all the sludge. Are there a couple plugs right there???
Old 02-09-2009, 02:02 AM
Yes, plug is upper left one in that cluster of four, upper right and lower left hold front cover to block, and the lower right, as you already know, holds ground cable to block. It must not be leaking much because it doesn't look washed like a heavy leak would. I would snug the cover bolts up, reseal the plug if it's loose, and even check the pan bolts in that area while you're there. Not that it will help your leak but since you're there, now would be a good time to clean and re-attach that ground cable. I hope this helps!
