Originally Posted by crash11x
Alright guys i have a 2000 7.3 powerstroke that wouldnt start in the cold weather unless its plugged in. if i dont plug it in it will start and run for maybe a min then just dies. i can hold the accelerator to the floor and no power and it will still die. the only way i can get it to start and stay running if it aint plugged in is keep starting it over and over till it starts up and shakes lik it gonna die then it finally starts to idle. now when im driving down the road between shifts in abot 2grand to 3grand on rpms the truck will bellow out white smoke and i can put accelerator to the floor and it has no power at all then it will finally clear up then it does it over and over again. any ideas?
There's a couple of things it could be, so let's name the most common. 1st & foremost, have you scanned for codes? It'll give you a general area of where your problem is. By the sound of it, I'd always check the fuel bowl/filter 1st. Check the condition of the filter & also the fuel. If the fuel is really cruddy-looking, your next place to check would be the pickup screen in your fuel tank. The screen is known for accumilating crud & could cause these problems. There are a couple of other things it could be, but check these areas 1st & see about getting some codes.
