HELP !!!!!!!!!! - Ford Powerstroke Diesel Forum
Old 01-29-2009, 03:14 PM
Question HELP !!!!!!!!!!
so my truck died and wont start now it has new gpr and glow plugs under valve cover wiring cps and i have been told its the injector pump, or the engine control module can anyone help my trucks been down for 3 weeks and we have a foot of snow and i want to play
Old 01-29-2009, 03:21 PM
Well first off you're really gonna have to tell us about your truck. What year is it, what motor does it have. What are the symptoms..does it crank? Does it crank and make odd colored smoke? Have you checked the oil level and the level of oil in the HPOP? Give us a few more details about your truck and trouble. Thanks.
Old 01-29-2009, 03:24 PM
its a 01 7.3 it cranks over fine it just dosnt fire there is fuel in the bowl and there it no smoke when i crank it over
Old 01-29-2009, 03:26 PM
Almostdunfukinwidit
Is your wait to start light on? Check the fuel bowl heater fuse. If its blown unplug fuel heater and replace fuse
Old 01-29-2009, 03:27 PM
i done all that work to it and it was running fine i shut it off and pluged it in the next morning i started it let it warm up went to leave and it died and hasnt run since
Old 01-29-2009, 03:28 PM
all the fuses were good and the light comes on for about 20 seconds the gos off like normal
Old 01-29-2009, 03:31 PM
Almostdunfukinwidit
Need to pull codes and check fuel pressure
Old 01-29-2009, 03:35 PM
i checked the codes bc the engine light came on when it died and it read no codes and thats when someone said it was the computer
Almostdunfukinwidit
What did you pull codes with?
Old 01-29-2009, 04:10 PM
a snapon odb2 reader
