10k problem.... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-28-2009, 11:17 PM Thread Starter
Randee Bowknee's Avatar
10k problem....
the other day i installed the 10k resistor....it snowed and i had to plow so i wanted to take it out...after doing so i plugged the sensor back in and truck ran fine for a minute....then idled like junk....went to rev it up and it very slowly reved and after i took my foot off the gas it stalled......had check engine light on and it wouldnt go off.....re-installed the 10k and runs fine....any clue? Maybe the 10k resistor wire stretched the female plug and wasnt getting proper connection??? I have no idea...
2001 F-250XL 4x4
K&N Cold Air
Foil Delete
05 Grille and Headlights
Wicked Wheel
Muffler Delete
4in turbo back exhaust
TW 6 position chip
Randee Bowknee is offline
post #2 of 8 Old 01-28-2009, 11:25 PM Thread Starter
Also pulled codes 1280, 1729,1211,1210
2001 F-250XL 4x4
K&N Cold Air
Foil Delete
Wicked Wheel
Muffler Delete
TW 6 position chip
post #3 of 8 Old 01-28-2009, 11:32 PM
harrys91rs's Avatar
Send a message via AIM to harrys91rs
1280:
Injector Control Pressure Sensor Circuit Low
1211:
Injector Control Pressure Higher/Lower than desired (engine on)
1210:
Injector Control Pressure Higher than desired (engine off)
1729:
4x4 Low switch
Try unplugging the ICP sensor and see if the idle changes.
2000 F250 7.3 SCLB 4x4
DP Tuner, Bean's Stage 2's, 38R, BTS, K3LA Train Horns
Best 1/4: 13.77 @ 97.19
Best 1/8: 8.72 @ 78.67
448Hp 904Tq
harrys91rs is offline
post #4 of 8 Old 01-28-2009, 11:35 PM Thread Starter
Are these things big problems or common with 10k mod?(besides 4x4)
2001 F-250XL 4x4
K&N Cold Air
Foil Delete
Wicked Wheel
Muffler Delete
TW 6 position chip
post #5 of 8 Old 01-28-2009, 11:59 PM
harrys91rs's Avatar
1211 is common with 10k i believe. As for 1280 and 1210, I don't think they are common with doing 10k. If unpluging the icp helps, it might be the icp sensor going or maybe bad/frayed wiring or bad connection to icp sensor.
448Hp 904Tq
post #6 of 8 Old 01-29-2009, 01:49 AM
TurboSevenThree's Avatar
Yes try unplugging the sensor and it will go back to an automatic setting for the HPOP pressure. It's not THAT common with the mod but if the sensor gets messed up that happens. You're not the first. It is very delicate. Gotta be careful with the mod. I think you hit it on the head more than likely in your first post there. Because typically ... it idles funny with a resistor ... if you take out the resistor and it still idles funny or worse or whatever, ... it HAS actual resistance now, so the sensor is screwed up. Be it terminals or what have you.
1211 is the one it sets, that description is what the resistor DOES. So that's nothing to worry about. I'm thinking it's the sensor. NO idea on the 4x4 though.
Old Truck: 00 F350 XLT DRW: basic first few mods. S&B, 4" straight pipe, gauges, CCV, EBPV and Wastegate line deletes, LED Sills, sweet custom headlights, smoked cab lights, Ventshades, Tint.
Traded in at 196k miles.
"Brand Newish" Truck: 02 Chevy S10 2.2L 5sp. Reg cab 4x2. Badass custom made shifter, foglights, 20% tint, AVS Vent-shades, Stock Intake mods, Electric Fan conversion .
~ 95k miles.
TurboSevenThree is offline
post #7 of 8 Old 01-30-2009, 06:15 PM Thread Starter
Do i unplug it b4 start up or while it is running unplug it?
2001 F-250XL 4x4
K&N Cold Air
Foil Delete
Wicked Wheel
Muffler Delete
TW 6 position chip
post #8 of 8 Old 01-30-2009, 06:18 PM Thread Starter
i had unplugged it......let it run....plugged back in and the service engine light came on and stayed on....only goes away when resistor is back in.....also makes truck shift hard if i go anywhere near 1/4 throttle and after shifting hard O/D light flashes.....and i just replaced the trans bout 1500 miles ago and def dont wanna damage it again at $3000
2001 F-250XL 4x4
K&N Cold Air
Foil Delete
Wicked Wheel
Muffler Delete
TW 6 position chip
