leaking fuel i think - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-28-2009, 04:19 PM Thread Starter
shadowe123's Avatar
can anyone help me on this.. on cold mornings ill star my truck after being plugged in and drive to work well when i get there its always dripping fuel out of the flywheel dust pan why is that???and its not alot im not even sure if its fuel it smells like it but sometimes its black..anybody have this problem or know about it???
AFE stage 1 intake
straight pipe
6 inch lift with 37/13.50r20 toyo mts
alpine iva-w200 screen with jl xr in the doors and 2 12" jl w1 behind seat
autometer phantom 2 gauges
DP TUNER 60 tow, 80 eco, and 140 SMOKE yea i love it
DirtAssassins Clothing
shadowe123 is offline
post #2 of 14 Old 01-28-2009, 04:21 PM
cliford's Avatar
check the back of the fuel bowl, two o rings are know to go bad. the reason the fuel is showing up down there and black is because it travels down the valley and drains down there.
soon to go?:
2000 f-250
soon to come?:
6.4 and spartan
cliford is offline
post #3 of 14 Old 01-28-2009, 04:26 PM
Tony V's Avatar
Check the Seperator valve!!! They are a B$tch...
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
post #4 of 14 Old 01-28-2009, 05:56 PM
where is the seperator valve ??? i have replaced the o rings on the filter housing for the drain and the other that has the plug on it but still have a leak uggggghhhhh
antifrez72 is offline
post #5 of 14 Old 01-28-2009, 08:52 PM
cliford's Avatar
are you sure none of the lines feeding into the heads are leaking? have you tried cleaning out the valley and run the truck through a cycle building up pressure then looking to see where the fuel is coming from
soon to go?:
2000 f-250
soon to come?:
6.4 and spartan
cliford is offline
post #6 of 14 Old 01-29-2009, 02:59 AM
Get an inspection mirror and examine the back of the filter housing by the drain valve. I've seen heater plug leak, crack in housing,(that was OBS thou) and water sensor. Also like cliford stated, check the lines from housing to heads.
Russ
Late '99 F-350 7.3l 6sp 2wd aftermarket dually kit 255,000mi
STOCK
Deeslfxr is offline
post #7 of 14 Old 01-29-2009, 03:41 AM
Quoted: 2 Post(s)
I had this problem on my 95. I had it serviced and when the fuel filter was changed they didnt screw the lid on the filter bowl right and the gasket got messed up. Anyhow get this taken care of asap. the fuel soaked my disk and i had problems with it slipping. The dealer where I bought it did the service work so the changed it under warrenty. funny how they can do that when the want to.
Builttuff is offline
post #8 of 14 Old 01-29-2009, 08:16 PM
guzzle's Avatar
One of the first fuel line seals to let go is the one on the back of the passenger's side head. It gets cooked by the turbo and down pipe. It's not too tough to get to but removing the turbo outlet spider makes access a lot easier. Also check the passenger's side 1/4" fuel line. The bracket/clip that holds it in place is known to rub a hole into the line.
Fuel that gets into the valley or runs down the back of the engine will mix with dirt/grease that is caked on the block and turn it to a dirty black color. It even disguises itself as oil.
02 F350 4x4 SRW EC LB Lariat
guzzle is offline
post #9 of 14 Old 01-31-2009, 12:47 PM Thread Starter
shadowe123's Avatar
oh ok im gonna have to look.. its not leaking rel bad but it is a little and not everyday its weird but sometimes i can smell it in the cab it sucks
AFE stage 1 intake
straight pipe
post #10 of 14 Old 02-17-2009, 07:45 PM
1qwikef's Avatar
did you ever get this fixed cause my truck just started doing the same thing. im new to the p/s so im kinda in the dark. it only seams to do it when it cold out and when i first start it. the other day i noticed it so i cleaned out the valley good then drove its around for about 30min and it didn't leak at all. then today i go out and start it and it was dripping like crazy. it look like it may be coming from the white 2 wire plug on the fuel bowl but im not %100 sure.
00 ex cab stroker tow rig
97 honda civic hatch back.. 714 whp@30 psi (race car)
1qwikef is offline
