Cracked HPOP? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-24-2006, 12:05 PM Thread Starter
Cracked HPOP?
I have a 95 van with a 7.3 powerstroke with 180k miles on it... I have had a minor oil leak for a while, but haven't been able to tear it apart to fix it. (Y'all know how easy vans are to work on) Last weekend I developed a miss in the engine and when I parked the van, the oil leak was massive. Knowing the HPOP is crucial to the proper running of the motor, I figured the two were related. No power idle is fine, but anything above that it misfires.
I bought a code reader and plugged it in, but I wasn't able to retrieve any codes from it.
Since I have to fix the oil leak anyway, I tore it down and it looks like the oil is coming from under the HPOP. The area under the HPOP looks like someone powerwashed it, so I know that the oil is spraying into that area. I removed the HPOP and after cleaning it up I inspected it in the area that I figured it might be leaking from. Has anyone had a problem with the HPOP cracking near the IPR? It looks like there might be a small crack near the casting webbing on the pump, but it's really hard to tell without testing the pump. All the o-rings were dry and fully intact, so I know it wasn't coming from there.
One thing that I noticed on my engine is that I don't have the QD fittings on the HPOP. All my fittings are JIC #6. I've browsed the threads in the forums and nobody has ever mentioned that fact. Since the JIC fittings hold the adapters into the HPOP in addition to the locktite, wouldn't it make sense that changing to JIC would solve a lot of o-ring problems that I've been reading about. It also seems to me that the QD fittings are more expensive than the JIC fitting.
Since I have everything apart, and have some room to work, I'm definately pulling the valve covers and checking the harnesses in there. (Since I've read about harness problems under the valve covers.) I really don't want to have to put everything back together to find that I developed two simultaneous problems and was too lazy to explore further. I replaced the Glow plugs and relay a few years back. I'll check them before I put it all back together. (Again... vans are not the easiest vehicles to work on.)
Any feedback would be greatly appreciated.
stod is offline
post #2 of 6 Old 12-24-2006, 12:11 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
I havent
found a cheap auto zone type code reader or even the small MAC or MATCO ones that will read a diesel yet so I know there are codes in it. I havent seen a hpop crack but anything man made and under pressure can fail. My buddy got a real nice code reader from mac the other day. Just like the one at auto zone here in town. I had 3 codes in my truck from my chip. It didnt pick up any of them. Good thing I have access to a Ford scanner.
post #3 of 6 Old 12-24-2006, 12:13 PM
International Threat
Marty's Avatar
Usually Orings break on the HPOP's and I'm not sure what might cause the crack. I haven't seen any related topics like this to link you to, sorry. Hopefully somebody like Marc will be along to help ya out!
Merry Christmas
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #4 of 6 Old 12-24-2006, 12:15 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
Yeah,
maybe a Tech will wonder by later. Maybe Marc.
post #5 of 6 Old 12-24-2006, 12:42 PM
Marty's Avatar
When I posted my response, only the original post was up there. After I posted I saw that you had posted. I in no way was trying to diminish what you said!
Anyways, Merry Xmas fellas...
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #6 of 6 Old 12-26-2006, 02:49 PM Thread Starter
Took my HPOP to work today and polished the area that I suspected might be leaking, but it only seemed to be surface casting cracks. I installed the HP oil lines on a forklift and applied deadhead pressure on them to see if they might be leaking. They didn't show any signs of failure. I tried pressurizing the pump with air and nothing seemed to be leaking from the housing. I'm going to re-install the pump and hope that my leak was from the mating surface between the pump and the front housing.
stod is offline
