Need Help - Ford Powerstroke Diesel Forum
Old 01-26-2009, 03:12 PM
Need Help
Had my truck on A/E this weekend. Contribution low on #3, 1211 code and the one that puzzels me is the icp. The truck idles like it has a cam up and down. The icp reads 690 when it idles up and 630 when the idle down. Any help will be greatly appreciated.
Old 01-26-2009, 03:16 PM
Sounds like you need a black CPS! Love the Avatar by the way!
Old 01-26-2009, 03:18 PM
Location: Little Rock Air Force Base,Arkansas and North Augusta,South Carolina
how bad is the surge on the idle?
Old 01-26-2009, 05:57 PM
I will have to check the cps. Thanks
It is a steady up & down. Thing is it does not do it when the chip is in stock tune.
Old 01-27-2009, 02:05 AM
Old 01-27-2009, 02:43 AM
Is stock position the only position where it doesn't lope? How long have you had the chip?
Old 01-27-2009, 03:15 AM
Stock is the only position that does not do it. I have had it about 1 year.
Old 01-27-2009, 03:53 AM
I would have to lean towards a problem with the chip. Will it set the code with the chip in stock tune or disconnected completely?
Old 01-27-2009, 04:05 PM
Contribution low #3 is the only thing I get in stock.
Old 01-28-2009, 03:17 AM
Excuse my ignorance but who makes the T/S chip? I would call them and explain your problem. Those guys usually have real good support. I think you have 2 problems, 1 being a bad chip and the other a bad UVC connection or bad #3 injector.
