7.3 hard starting - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-24-2009, 01:57 PM Thread Starter
seadoo48's Avatar
Feedback Score: -1 reviews
7.3 hard starting
when my truck is plugged in it will start no problem at all. But if i cant plug it in when i try to start it the next morning it just will not start! it has two new batteries a good built up altenater. i replaced all the glow plugs this past summer. one thing i noticed was when iput my tuner on level 5 it has a better chance of starting or in other words can get running but barely in level 5 but in level 1 forget it. Any ideas?? Thanks
seadoo48 is offline
post #2 of 9 Old 01-24-2009, 02:00 PM
Quoted: 5 Post(s)
is the relay good?
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 9 Old 01-24-2009, 02:26 PM
cliford's Avatar
i'd check relay. you can test it with a multi-meter
soon to go?:
2000 f-250
soon to come?:
6.4 and spartan
cliford is offline
post #4 of 9 Old 01-26-2009, 06:51 PM Thread Starter
seadoo48's Avatar
so i took a regular test light and relay clicked and both the big wires had power when key on and one small wire has juice
seadoo48 is offline
post #5 of 9 Old 01-26-2009, 07:16 PM
That sounds like its working. If both big posts have proper voltage when relay activated then its working. Only one little post should have voltage when activated. That is considered the coil. NChornet has a good gp system troublshoot on here somewhere.
2002 F-250 4x4 cc A/T
4" Magna Flow Exhaust
PHP Chip-Stock, 40, 60, 80, 100, Whisper
BF Goodrich 33s
ZooDad
Autometer Trans,
Pyro,Boost on the pillar
zeuss is offline
post #6 of 9 Old 01-27-2009, 05:04 AM
What year is the truck? Do you have the intake heater? If so, you didn't test the wrong relay did you? They are right next to each other, GPR is shorter and right behind IAH relay. Next would be testing glow plugs or checking UVC harnesses.
Russ
Late '99 F-350 7.3l 6sp 2wd aftermarket dually kit 255,000mi
STOCK
Deeslfxr is offline
post #7 of 9 Old 01-27-2009, 07:33 AM
My also does the same thing. Did a injector pluse test when the engine was cold and 4 or 5 had a weak pulse . change two of the injectors ( thats all I had at the time) Helped out quite a bit. I guess that they were clogged when it cold /clear when warm
jcraig is offline
post #8 of 9 Old 01-28-2009, 08:25 PM Thread Starter
seadoo48's Avatar
its an 01. i checked the rear relay..... replaced all glow plugs and 2 new batteries 3 monthe ago
seadoo48 is offline
post #9 of 9 Old 01-29-2009, 03:51 AM
Have you had someone perform a glowplug test with s scantool? That would help in finding out if power is actually getting to the plugs.
Russ
STOCK
Deeslfxr is offline
