Smoke
Hey guys
Does a lot of blue smoke when cold signify piston rings are finished or injector(s) are finished? |
what year?? how much milage? ever had injector o-rings replaced? is it using oil? does it start hard?
smoke
It's 1997 250. 187000 kms. (though many idling hours). Never replaced injector o-rings. It does burn oil. It is hard to start when cold.
A lot of idling is believed to hurt your truck and cause wet stacking. Wet stacking is fuel residue buildup.
i would bet on injector o-rings being bad
You said it uses oil, how much does it use.
Oil
In about 2000 km of driving it's probably used about 2-3 liters of oil. But it also leaks a lot of oil out of the crankcase breather on top of the driver's side valve cover.
2-3 liters! Dang thats alot of oil brotha....i don't know how uch your leaking but your obviously burning some too i think. Have you done a compression test?
Comp. test
I haven't done a compression test because you need some special tools and pressure gauges.
If my oil smells a lot like diesel and the truck smokes a lot, could that also mean injector o-rings? Hey at least if my truck uses & leaks a lot of oil and I have to add a couple liters every few thousand k, I'll never have to do an oil change.
