rattling in motor
When driving at lets say 45 all sounds tight under the hood...yet when givin alittle more fuel not much just slightly more theres a rattling noise..when the pressure is took off the pedal the motor sounds tight again..it sounds like the valves..If it is the valves how can I adjust them? What do you think
there is no valve adjustment....
Could you be hearing an exhaust leak?? sounds more likely..... |
What are you driving?
reply
I'm driving a 01 w/7.3l
fuel
I found out the sound that I'm hearing is one called fuelcackling...What actually is this...Bad fuel?Your takes are....
Ford Diesel Noise????? I know(I think) what you are referring to. Just enuff throttle to make it happen but not enuff to change the speed of the truck. Ihope its normal cause I have had it since day 1.
yep
Your correct!Maybe after the hutch mod and lifter mod that will go away. Floor is open to any thoughts on this.
