cutting out - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-19-2006, 12:22 PM Thread Starter
cutting out
97 F250 powerstroke, when I press the gas it cuts out, revs, cuts out, revs, almost perfect unison. Any ideas?
classicpw is offline
post #2 of 7 Old 12-19-2006, 01:33 PM
<<---"Shadow"---
sea71's Avatar
bump bump bump
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
post #3 of 7 Old 12-19-2006, 01:37 PM
Powerstroke Techie
djsdiesel's Avatar
more info?? check engine light? does it die? sounds like it could be the accelerator pedal.
99.5 F-250 PSD AT 4x4, 4in lift, 37 13.5 18 Pro comp Extreme A/T's, S&B Intake, GTP38R, DP Tuner custom programs (140 Agg., 120 sled pull, 80 tow and 60 tow), Rosewood DIY stage 2 injectors, BTS Trans, 5in exhaust no muffler, 6 oh intercooler, Ford AIC, EBPV delete, Foil delete, T/C lock up mod, Pusher Fuel Pump, Three Chime train Horns
djsdiesel is offline
post #4 of 7 Old 12-19-2006, 03:06 PM Thread Starter
no engine light. It seems to happen after the engine is warmed up. After driving about 3 miles it starts hesitating when I press the gas. Just 5 days ago I replaced the right bank wire harneses, the IDM, and the Cam pos sensor.
post #5 of 7 Old 01-22-2007, 07:36 PM
That sounds just like the problem I just had. I put in a new fuel filter this evening and run it for about 3 hours of mixed driving and idling... so far so good. Hopefully the cheap and easy was the right thing.
runninbhind is offline
post #6 of 7 Old 01-23-2007, 11:42 PM
99 7.3's Avatar
i was having the same problems, but mine was dying. i put two different cam sensors in it and then put a boost sensor in it also. now all is good. maybe this will help, however not sure what yr. ur ride was and if u have turbo.
99 7.3 is offline
post #7 of 7 Old 01-24-2007, 12:01 AM
99 7.3's Avatar
i almost for got. if you have chip in it pull it out and see what that does. sometimes chips go bad and that will cause it.
99 7.3 is offline
