Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
  #11 (permalink)
Old 01-10-2009, 10:07 AM
96whitehouse 96whitehouse is offline
yeah i would plug it in and check everything when you can but let us know if it still dont work
  #12 (permalink)
Old 01-10-2009, 09:25 PM
scpbmxer01 scpbmxer01 is offline
It started up this afternoon after it sat in the sun for awhile I've got it plugged in tonight so hopefully it starts
  #13 (permalink)
Old 01-10-2009, 09:33 PM
TurboSevenThree TurboSevenThree is offline
I miss the 90's. =[
Originally Posted by OregonStroker View Post
make sure your GP's are actually turning on. I had a similar issue where my PCM stopped sending a signal to the GPR. So, I had to rig up a custom GP switch. Let me know if you figure it out. Otherwise I will hook you up with the diagram and parts list. A few on this sight have adopted my design, works great. And your GP's dont turn on when you turn the key to listen to music.
I'd like to adopt that design I like the sounds of it. Could you PM me a write-up/diagram/something?
  #14 (permalink)
Old 01-10-2009, 09:46 PM
hey buddy its good to hear that and i would check you gpr again an see if it went out agian and check your gp and you gp wires and make sure everything is reading good
  #15 (permalink)
Old 01-11-2009, 07:36 PM
it started up this morning after having it plugged in no sweat. Are there any write ups on how to check gp's and gp wires? as well as how to tell if my gpr is good or bad. I am throwing two codes could the be the reason for this they are?
p0670
p0683
  #16 (permalink)
Old 01-11-2009, 07:42 PM
Tyler Tyler is offline
scuffs *****
Send a message via AIM to Tyler
P0683 Glow Plug Control Module to PCM Communication Circuit
P0670 Glow Plug Module Control Circuit
  #17 (permalink)
Old 01-11-2009, 07:44 PM
p0670 - GPCM Glow plug control module control line failure. Open/grounded circuit, open/shorted GPCM, failed PCM
p0683 - GPCM glow plug control module communication line failure. Open/shorted circuit, failed GPCM, failed PCM
  #18 (permalink)
Old 01-11-2009, 07:45 PM
lol beat me to it
  #19 (permalink)
Old 01-11-2009, 07:55 PM
do i need to replace my glow plug control circuit?
  #20 (permalink)
Old 01-11-2009, 07:58 PM
scuffs *****
Originally Posted by 96whitehouse View Post
lol beat me to it
Sure did
I'm not sure. Hopefully as tech can look at this soon and tell you more. I've never had a problem with my GP. They are new, didn't need replaced but replaced them anyway cause we had extra $$ lol
