Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 01-10-2009, 06:34 AM
bigbad4x4 bigbad4x4 is offline
Need MORE help please
My truck takes a long long time to crank up, i noticed that when i was cranking the engine that the oil press gauge was not reading then all of the sudden the gauge started reading and it fired up, Im assuming that the HPOP reservoir
is going dry, no external leaks, so if the res is going dry what would be the fix??
Old 01-10-2009, 07:43 AM
Did a search on this site
Someone said something about doing a "jack test", does anyone know what this test is??
Old 01-10-2009, 02:17 PM
Unhappy
I guess I will bump it..
Old 01-10-2009, 07:50 PM
mnstroker mnstroker is offline
The oil pressure guage is from the lpop not the hpop. Mine cranks for a few seconds before the guage moves also. Long starts could be the glow plug relay, or injector orings.
Old 01-10-2009, 08:19 PM
TurboSevenThree TurboSevenThree is offline
I miss the 90's. =[
Agree 100%!
Old 01-12-2009, 07:02 AM
new injectors installed about three wks ago, thats when all these other problems arised. I had the GP system ck'd only found #7 GP not working, so when i replaced injectors I replaced the #7 GP..
