i changed my plow plugs today and after the install it runs like crap like its got a skip, it's a 1999 power stroke. when i toke the old glow plugs out oil when' down the glow plug hole. so any ways after i got done i started it and runs like crap.so i like it runn for 10 min, you know maybe clean it self out. well it still runs bad, i mean bad, idles rough. PLEASE SOME ONE HELP.
oh and it all stock besides the 4in dp back steve |
you cant get enough oil in a cylender by just removing a glow plug to cause a problem....
My guess is either you accidently partially unplugged eitehr an injector or the under valve cover harness.....would be the most logical place to start |
i know i didn't drop anything in there and when i strated it it dosen't smoke but i mean i sounds like i have a cyclider down or some thing. i back it out of the shop it see if it would clean out but it had no power and souds funnie.
again...im gonna bet its an electrical issue causing an injector not to fire...get the valve covers back off and check for a partially disconnected injector or under valve cover connection
thank you. it was the right side by the heater box . it sucks that the vavle cover dose not come out or there, tight, tight like a turtle.
powerpuff, could you clarify. wire unpluged?? or something else??
