Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 12-15-2006, 04:22 PM
massy massy is offline
Question hard start 2001 super duty
need help,
i have extended crank time on this 7.3.
some times the c.e.l comes on with a code po1211/ uncontrolable i.c.p..
while watching pressure and i.p.r. duty cycle i can see the the command for higher pressure, but the pressure does not exceed about 2000 p.s.i..with a 30% or more duty cycle.
the truck runs and starts ok warm. the glow system checks out.there is oil in the resivoir.
cuold this be a bad high pressure pump?
it has good pressure at hyway speeds.
any ideas? thanks for the help.
Old 12-15-2006, 05:20 PM
wesjones wesjones is offline
hmmm......could be the pump....could be a restriction somewhere else in the system. injectors maybe.....altough you would be getting a code for that.
Beats me
wes
Old 12-15-2006, 09:08 PM
No-Neck-Shrek No-Neck-Shrek is offline
How many miles on the truck ?
How did you check the glowplug system ?
Is the truck stock ? If not what is on it ?
