Engine light - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-15-2006, 08:18 AM Thread Starter
Engine light
Has anybody had this problem. I have installed an edge juice attitude w/ monitor
no problem. but when i accelrate or should i say use the edge "juice" the check engine or service engine soon light pops on for a bit than goes off. should i worry? does this happen to anyone? i do know, since the install the cold weather makes it hard to start. but other than that the only problem is it will pass everything on the road but the fuel pump.
and on another note how do yall feel about the anti lock brakes on this very heavy trucks mind won't stop very quickly
RichardT is offline
post #2 of 6 Old 12-15-2006, 09:55 AM
same problem
Just letting you know I have the same problem on my 03 f 350. If you read in the Edge manual it says the light could come on. Mine always comes on.
sprekj is offline
post #3 of 6 Old 12-15-2006, 09:59 AM
strokermann's Avatar
i would suggest reading the code. its probly going over the 24psi of boost and setting off the cel. but with most chip from what i heard the light comes on and not to be to alarmed
CB Radio- General Lee
7.3l 99 f-250 SD
4 INCH TURBO BACK TO 6 INCH MITER CUT STACKS CURIOSTY OF GRAND ROCK AND COWBOY DIESEL PERFORMANCE.
TS 6 POSTION CHIP. stock,high idle,50,75,100,140hp.
strokermann is offline
post #4 of 6 Old 12-15-2006, 10:03 AM
purduefarmboy460's Avatar
Send a message via AIM to purduefarmboy460
That is exactly what it sounds like, you should check the code, then talk with our vendors to get a sensor eliminator, or a relief valve for your map line, check out my garage for pics!!
purduefarmboy460 is offline
post #5 of 6 Old 12-15-2006, 09:19 PM
Its probably from the ICP sensor, most programmers increase the pressure to the injectors, ICP is reading the higher pressures.
2000 F550 : AFE 1, HX, Walker BTM, Zoodad, Diablo Predator,......more to come !
No-Neck-Shrek is offline
post #6 of 6 Old 12-18-2006, 05:08 AM Thread Starter
yea, its been doing it with out any problems so i figured it was something with the chip/ in fact i do remeember reading somehting about that in my manual. Thanks for the vote of confidence. & MERRY CHRISTMAS
RichardT is offline
