Refuse to be raped by "stealerships" - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-13-2006, 11:43 PM Thread Starter
Hi folks, I've got a 97 F250 with a 7.3. It started to studder one night, the next day I tried to start it, it idled very rough then shut off. I bled the water and changed the fuel filter, nothing. Had it towed to a dealer, they wanted $2600 to fix the right bank wire harnesses, cam pos sensor and the idm. I paid for the diagnostc and had it towed to my garage. 8hrs and $700 in parts later i fixed all that they said it was. It still won't start. It's cranking strong(my batteries are a month old) but it feels like it's not getting fuel. A friend of a friend works at a Ford dealer and I called him, he put me in touch with their deisel mechanic. He seems to think it's the fuel pump. It's been leaking "fluid" for a few months now, I thought was oil, but now i realize that i'm pretty sure that it's fuel. If there's a leak will that out air in the fuel system and prevent it from starting? What's the best way to check if the pump is working? thanks for any info.
classicpw is offline
post #2 of 5 Old 12-14-2006, 03:57 AM
im fat and ugly
stump0331's Avatar
to powerstroke.org
2004 Excursion
stump0331 is offline
post #3 of 5 Old 12-14-2006, 06:45 AM
thats pretty simple....there is a schrader valve on your fuel filter housing. You will need to build a 90 degree fitting in order to get a fuel pressure gauge on it....but once you do check your fuel pressure while cranking there and let us know what it is....
mschn99 is offline
post #4 of 5 Old 12-14-2006, 03:38 PM
jojo1928's Avatar
Exclamation fuel pump
I just got mine back from the stealership With the same problem. The lift pump took a dump and they said it caused the high pressure pump to dump as well as a couple of other parts. $3500.00 and two weeks later I got my truck back. Find A reputible shop and steer clear of the Steelers.
jojo1928 is offline
post #5 of 5 Old 12-15-2006, 02:04 PM Thread Starter
Here's an update to my problem. The truck is fixed, it wasn't a fuel issue. Apparently when I installed the Cam sensor I cracked it and it wasn't in all the way. I put the old part back in and it fired up. If i would have first replaced the harnesses it probably would've fired up, but instead i replaced all the parts that the stealership wanted to replace. now I've got a leak issue, it smells like oil.
