MPG drop - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-06-2014, 02:26 PM Thread Starter
delta99's Avatar
MPG drop
My truck used to get about 18.5-19.5 mpg, while my daily commute was 32 miles, and about 95% highway. I now get around 14.5-15 mpg. I moved and my commute is now 6 miles, all city stop and go. I know there would be a difference between city and highway, but I didn't think it would be that drastic. Can the EBP sensor cause a reduction in MPG even though I have the EBPV unplugged at the turbo? The sensor was replaced last summer, and I cleaned the tube from the manifold at that time. Actually, I took it off and inspected it, but it didn't need cleaned. So can my fuel economy drop be completely contributed to my change in commute, or should there be something else I should check. I see no fuel leaks either
1996 F250, 7.3L, auto trans, 4x4, eclb, TS Performance 6 position chip
delta99 is offline
post #2 of 3 Old 05-06-2014, 02:31 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Whats the old rule...a body in motion tends to stay in motion... when your out runnin down the highway your truck is not using the extra force to get that weight into motion. Stop and go is just brutal on mpg's.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 3 Old 05-06-2014, 02:50 PM
I had the same type thing happen to me last year and it turned out to be a sticky rear caliper. I track my mileage religiously and noticed a definate step change in MPG's but couldn't figure out why.
When I had a sticky front caliper (on another occasion), it was obvious because the truck tended to pull to one side but I never noticed the rear until I caught a whif of "hot brakes" when I pulled into my driveway. My rear wheel was so hot, I couldn't put a hand on it! It could have led to a blow out!
Now, I periodically walk around my truck and touch each wheel near the hub while gassing up.
2007 F-350 W/Lariat package
4x4 6.0l diesel engine
Leveling kit and 35 inch tires
Coolant Filter kit
EGR Delete Kit
Glowshift Gauge Pillar Pod (EGT, Trans Temp, Fuel Pressure and Coolant Pressure)
Fuel System Blue Spring Upgrade
SCT Tuner
Diamond Eye 4" stainless steel turbo back exhaust kit
ScanGuage II
Zoodad Mod
Backup Cameras from Tadibrothers.com for both truck and 25' Travel Trailer
DJGut is offline
