boost pressure - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-06-2014, 02:21 PM Thread Starter
delta99's Avatar
boost pressure
I recently installed some autometer gauges, and was a little surprised when I saw what my boost actually is. The truck is stock besides the mods in my sig, and is fairly slow, so I wasn't completely surprised, but I thought it would put out more than what it does. Cruising I have 2 psi, normal acceleration might reach 5 psi, all-out WOT maxes out at 12. Are these numbers low, or normal for a stock engine with 250,000 miles?
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #2 of 5 Old 05-06-2014, 02:56 PM
700xxmaniac's Avatar
That's very low, some have seen 20psi with a stock truck. You gota have a leak somewhere
Sent from AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #3 of 5 Old 05-06-2014, 03:11 PM
Quoted: 28 Post(s)
That's low. Check your up pipes and intercooler boots. I get 15-16 psi on stock tune and I have 287k on my truck.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #4 of 5 Old 05-06-2014, 04:15 PM
Rodslinger's B1TCH
Pull the intake pipe off the turbo and check out the turbo wheel.
steve604 is offline
post #5 of 5 Old 05-08-2014, 11:42 AM Thread Starter
delta99's Avatar
Thanks...I suspect up pipes. I have removed all the boots, degreased all the oil from them and tightened the clamps. I had the spider off, and the compressor wheel looks good and has no play in it. I think I can even hear an exhaust leak
delta99 is offline
