Fuel filter gasket - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-06-2014, 03:18 PM Thread Starter
delta99's Avatar
Fuel filter gasket
I recently replaced my fuel filter, and when I started the truck, fuel was spraying out from the top of the fuel bowl. I tightened the new lid as tight as I could get it. I took it back off, and noticed the new gasket looked nothing like the old one. The new one was basically a flat rubber gasket with an o-ring shape molded in at the outer circumference. The old one was flat on top and tapered on bottom. I also noticed the new lid was deeper where the threads are and has more threads. I wound up using the old gasket with the new lid. I thought I had read someone having this problem before, but can't find the thread now. I got the filter at auto zone I believe. Does anyone have a good part number for a fuel filter that fits and seals properly so I can get the right one next time? Doesen't have to be autozone. Thanks
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #2 of 8 Old 05-06-2014, 07:05 PM
timmyboy76's Avatar
been running them for 4yrs now..no leaks
Wix 33818 & Napa 3818 Fuel Filter: FleetFilter Secure Online Store
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
The Following User Says Thank You to timmyboy76 For This Useful Post:
delta99 (05-07-2014)
post #3 of 8 Old 05-07-2014, 10:36 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Yeah I also prefer the wix gasket... I don't use the filter though. If it leaked you tightened it too fast, and it kinked. You must tighten it very slowly and it really doesn't have to be that tight
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 8 Old 05-07-2014, 06:01 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
i always use the oem filter and cap and never have issues.
the oem filter has a beveled o ring, do the others have this as well?
i changed my dads with a cheap filter from napa and it also had the beveled oring.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 8 Old 05-08-2014, 07:35 AM
timmyboy76's Avatar
no bevel on the wix from fleetfilter.
post #6 of 8 Old 05-08-2014, 12:43 PM Thread Starter
delta99's Avatar
Thank you. The one I had that leaked wasn't beveled
delta99 is offline
post #7 of 8 Old 05-08-2014, 12:59 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Wix doesn't have or need a bevel its a different type of seal and far superior IMO...
post #8 of 8 Old 05-09-2014, 07:09 AM
GoodwinFord's Avatar
WIX all the way which is the same as NAPA. For almost every wix number just drop the first number of the 5 digit wix number and the last 4 is the NAPA part number.
GoodwinFord is offline
