BWD ICP sensor - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-01-2014, 02:37 PM Thread Starter
Treyloco's Avatar
BWD ICP sensor
Has anyone used this brand. I bought one yesterday and the truck ran worse then it did with the bad ford sensor.
Treyloco is offline
post #2 of 4 Old 05-01-2014, 03:01 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
You most likely have air in your hpo system from replacing your icp and it should clear up as you drive.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 4 Old 05-01-2014, 05:10 PM Thread Starter
Treyloco's Avatar
The only problem is, I put the ford sensor back in and I have a slightly rough idle the other is like I have a hot cam
Treyloco is offline
post #4 of 4 Old 05-03-2014, 08:53 PM Thread Starter
Treyloco's Avatar
First sensor was a dud. They got me a new one and the truck runs like new
Treyloco is offline
