2000 7.3 crazy white smoke after injector change, no boost - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-29-2014, 01:57 PM Thread Starter
Seth2500's Avatar
My old man bought a 2000 f250 at an auction a few weeks back. It didn't start, so he got it for a fairly good deal, or so he thinks. Whenever he plugged it in, it would start, but if it was 70 degrees out and wasn't plugged in, no start.
I replaced all 8 glow plugs, the glow plug relay, the under valve harnesses and 2 injectors that were bad. The air filter was black and completely clogged so I changed that too.I went to change the fuel filter and when I drained the fuel bowl, what came out was clear all the way through and smelt like alcohol, not diesel. Now the truck will start and die within like 5 seconds. Sometimes it will start up great, but it continuously DUMPS white/grey smoke while idling and driving. Builds a max of 3psi boost, and won't accelerate past 50-55 mph.
Not sure if it's a turbo issue, I may be wrong so correct me if I am, but I believe a bad or leaking turbo can cause the white smoke. Maybe I messed something up when I work on it, not sure.
I cleaned his EBP sensor and tube, seemed to help a little but not much. ICP sensor had oil in it, could this be an issue?
I did put it down to the station and filled it with diesel and a fuel additive to get diesel back through it instead of whatever the previous owner was using.
Any ideas or suggestions would be great, I did what I could do, but without access to a scanner to pull codes, I'm at a loss.
03 Lariat supercab shortbox 7.3 F250
6 in lift, 35's on 18in Fuels, TW tunes, glowshift gauges
AFE stage II intake, 4in turbo back exhaust, 7in tip
Seth2500 is offline
post #2 of 14 Old 04-29-2014, 02:06 PM
Quoted: 27 Post(s)
If the ICP sensor had oil in it the sensor is done. Might need a new pigtail to if it got oil in it. Unplug the ICP and see if that helps. Unplugging it just sends it into default parameters and won't hurt anything.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
The Following User Says Thank You to strokin-7.3 For This Useful Post:
Corey@CNCFAB (04-29-2014)
post #3 of 14 Old 04-29-2014, 02:13 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
Replace the icp and icp pigtail and then get a blue Tooth obd2 connector and the torque app for an android phone. Then you will have a $20 scanner. But it takes a while to get the adapter in.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 14 Old 04-30-2014, 06:34 AM
Joe0816's Avatar
If u can get to 50mph anyway you should be getting more then 3 psi, does it have gauges or what? Could either be a faulty gauge or line to gauge, but sounds like a boost leak. Check inter cooler boots, inter cooler, and such, go over the whole system or get a boost leak tool to see if it holds pressure. Does it idle fine? Check engine light on? Even though your icp may be bad, may not throw a code unless unplugged.
2001 F250 ECLB 7.3 PSD 219,000 miles
S&B Intake
Flo-Pro 5" SS Exhaust
ISSPRO EV2 Boost, Pyro, Trans
David Lott Tunes
Riffraff HPx, FRx & AIH Delete
Resse Gooseneck Hitch
Non-EBPV Turbo
Joe0816 is offline
post #5 of 14 Old 04-30-2014, 07:20 AM Thread Starter
Seth2500's Avatar
It has gauges, they were installed by the previous owner so I suppose they could be wrong. It idles great, just dumps white/grey smoke out while idling, and when driving it. No check engine light, but I'm sure there's some codes. Unplugged the ICP(which did throw a code) and idle doesn't change at all, but I'm still going to replace it.
Seth2500 is offline
post #6 of 14 Old 04-30-2014, 07:58 AM
Joe0816's Avatar
Are you sure the two injectors you replaced were the only bad ones?
S&B Intake
David Lott Tunes
Non-EBPV Turbo
Joe0816 is offline
post #7 of 14 Old 04-30-2014, 01:53 PM Thread Starter
Seth2500's Avatar
When I pulled off the valve covers, those were the only two that made the truck stubble when unplugged. After I replaced them, I one by one tested all 8 again, and each one made the truck stumble, to me showing they were all working injectors.
Seth2500 is offline
post #8 of 14 Old 05-01-2014, 06:10 PM
heykw's Avatar
Could it have been water that came out of the the drain bowl?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #9 of 14 Old 05-01-2014, 09:14 PM Thread Starter
Seth2500's Avatar
it was for sure clear enough to have been water, but it smelt like straight alcohol. I know you can run all sorts of alternative fuels in these trucks but I have no clue what it was, or if it could cause other fuel related components to fail
Seth2500 is offline
post #10 of 14 Old 05-02-2014, 01:08 PM
heykw's Avatar
My bet is #1 diesel av fuel.
What is your location?
heykw is offline
