Weird noise? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-24-2014, 07:48 PM Thread Starter
Lunnzz's Avatar
Weird noise?
So recently my truck started to make an odd noise it started when I got on it merging onto the hwy. The noise is a whine almost like a turbo whine but this is in addition to the turbo whine. Truck still runs the same, performance is not affected. I pulled the inlet tube off the tube and the impeller looked good no shat play, no oil inside. I checked all my inter-cooler couplers and made sure clamps were tight and tried my best to make sure there were no leaks in the couplers I could not see. So not sure if it is an accessory on the engine or what. Noise is there at idle also but like I mentioned truck still runs the same.
Thanks
2001 F-250 Superduty
Edge programmer
AirRaid intake
4" open exhaust
6" lift
37x13.50x18 Toyo mud terrians
Lunnzz is offline
post #2 of 5 Old 04-25-2014, 05:01 PM
timmyboy76's Avatar
anyway of uploading video?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 5 Old 04-25-2014, 08:17 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 331 Post(s)
Do you still have the factory donut gaskets? I'd check for soot around there on the up pipes.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #4 of 5 Old 04-25-2014, 08:32 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
sure your not hearing turbo surge?
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #5 of 5 Old 04-28-2014, 08:46 PM Thread Starter
Lunnzz's Avatar
I've had the truck for just over a year and this started one day out of the blue. I am sure that the up-pipe gaskets are OEM I'll have to check those for soot.
Thanks
Edge programmer
AirRaid intake
4" open exhaust
6" lift
Lunnzz is offline
