Long crank but runs fine once it starts - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-23-2014, 07:23 AM Thread Starter
I tried another forum, but got no responses. Maybe I can find a guru here Thanks in advance!!
I've spent a couple hours searching, but can't seem to find anything I can use. I appreciate your patience.
Here is what I am seeing:
My '99 F350 cranks for 5 -8 seconds before it starts. Once is starts it runs strong. Some, but not excessive smoke which goes away a couple seconds after it starts.
I've checked:
- Batteries - 12.7 - 12.8 Volts. About 10.7V cranking. Returns to ~13.5 V after GPR opens.
- GPR - works as it should
- Glow Plugs - one is bad, but the other 7 are fine plus it has been in the 60s when I have tried to start it.
- I've pulled fill screw on the HPOP. It is consistently within 1/4"of the top.
- I have to add only about a quart of oil during my 5000 mile oil change interval so I am not really losing any oil.
- No oil in ICP Connector
- I used my AE scan tool - no codes, but using the monitor function, I see the Injector Control Pressure at nearly 0 for most of the time it cranks, then as soon as the ICP starts up it starts and runs. From what I have found, this makes sense since the ICP needs to be around 500 psi to trigger the injectors.
Here is a print out from my AE Scan
Time ICP ICP%
05:21:57.289, 0.00, 14.84,
05:21:57.835, 0.00, 14.84,
05:21:58.271, 0.00, 14.84,
05:21:58.599, 0.00, 14.84,
05:21:58.927, 0.00, 14.84,
05:21:59.239, 0.00, 14.84,
05:21:59.551, 0.00, 14.84,
05:21:59.878, 0.00, 14.84,
05:22:00.190, 0.00, 14.84,
05:22:00.487, 0.00, 14.84,
05:22:00.814, 0.00, 14.84,
05:22:01.126, 0.00, 39.45,
05:22:01.423, 0.00, 45.70,
05:22:01.735, 3.39, 51.95,
05:22:02.031, 21.49, 58.20,
05:22:02.343, 58.26, 64.06,
05:22:02.858, 169.13, 64.84,
05:22:03.279, 619.38, 64.84, < --- Truck Starts
05:22:03.622, 1136.38, 64.84,
05:22:03.950, 1799.32, 64.45,
05:22:04.277, 3563.58, 38.67,
05:22:04.574, 2915.34, 34.37,
05:22:04.917, 2364.40, 30.86,
05:22:05.245, 2009.74, 27.73,
05:22:05.541, 1754.64, 25.78,
05:22:05.869, 1571.37, 23.83,
05:22:06.165, 1418.64, 22.26,
05:22:06.477, 1289.11, 21.09,
05:22:06.805, 1181.07, 19.53,
05:22:07.117, 1090.57, 19.14,
05:22:07.429, 1024.95, 18.36,
05:22:07.928, 934.45, 17.19,
05:22:08.365, 895.42, 16.41,
05:22:08.692, 870.53, 16.01,
05:22:08.989, 817.36, 15.62,
05:22:09.347, 797.00, 15.23,
05:22:09.659, 776.07, 14.84,
05:22:09.987, 773.24, 14.84,
05:22:10.315, 750.05, 14.45,
05:22:10.642, 732.51, 14.45,
05:22:10.954, 715.54, 14.06,
05:22:11.282, 710.45, 14.06,
05:22:11.609, 709.89, 14.06,
05:22:11.921, 706.49, 14.06,
05:22:12.233, 694.61, 13.67,
05:22:12.561, 704.23, 13.67,
05:22:13.060, 673.12, 13.67,
05:22:13.513, 669.16, 13.28,
05:22:13.840, 682.17, 13.28,
05:22:14.137, 676.51, 13.28,
05:22:14.449, 655.02, 13.28,
05:22:14.776, 656.15,
I guess my basic question is: Why does the high pressure oil system fail to build pressure for about 5 seconds (see data above) then seem to work perfectly? Since the ICP% stays low this whole time, it appears the system isn't calling for pressure ????
Stuck IPR? - But, my behavior is very consistent. It is the same every time. I would think if it were sticky it would stick sometimes and not others. Plus, wouldn't the ICP% go up and not get the appropriate response?
Electrical? - Again, I would think it would either work, not work or be intermittent - not the same delay to build pressure every time.
Please give me your thoughts.
ColoradoOiler is offline
post #2 of 9 Old 04-23-2014, 09:09 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Unplug the ICP sensor and try again.
Also do an HPOP test. WOT run. Go somewhere that you can go from 60 to 80 and measure the ICP pressure and % like you did for the starting. That will show condition of the HPOP itself.
Your % at idle seems a bit higher than it should be. I hover around 10%
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 9 Old 04-23-2014, 02:04 PM
Here is what I see for a warm start of my 2001 van. A mechanic that looked at it said he thought it was a little slow starting. I get ICP as soon as it starts turning over:
time_s icp ipr rpm
1 0.000 0.2 14.84 0
2 0.048 18.7 14.84 14
3 0.096 37.2 14.84 34
4 0.145 55.7 14.84 54
5 0.192 74.3 14.84 74
6 0.240 92.8 14.84 94
7 0.288 111.3 14.84 115
8 0.336 129.8 14.84 135
9 0.384 174.1 14.84 155
10 0.432 269.6 19.92 170
11 0.480 365.1 25.00 174
12 0.528 462.6 30.47 178
13 0.576 560.4 35.55 182
14 0.624 658.1 40.63 187
15 0.672 755.9 45.70 191
16 0.720 853.7 50.78 195
17 0.768 951.4 56.25 199
18 0.816 1021.7 58.20 203
19 0.864 1092.1 59.38 205
20 0.912 1162.4 60.16 206
21 0.960 1232.7 60.94 208
22 1.008 1303.0 61.72 210
23 1.056 1373.3 62.50 212
24 1.104 1443.7 63.28 213
25 1.152 1514.0 64.45 215
26 1.200 1603.3 64.84 217 <---- start
27 1.248 1702.0 64.45 246
28 1.296 1800.8 64.45 289
29 1.344 1899.6 64.06 332
30 1.392 1998.3 63.67 375
31 1.440 2097.1 63.67 418
32 1.488 2195.9 63.28 461
33 1.536 2294.6 63.28 504
econoPSD is offline
post #4 of 9 Old 04-23-2014, 03:59 PM Thread Starter
More AE results.
Thanks Schlutzer & Econo
Here are a couple more data sets, but I need help understanding if they show a problem or what
Here are data with ICP Unplugged
Time ICP Time ICP%
04:38:03.430 0 04:38:03.664 14.84
04:38:04.117 0 04:38:04.304 14.84
04:38:04.725 0 04:38:04.866 14.84
04:38:05.334 0 04:38:05.474 14.84
04:38:05.630 0 04:38:05.739 14.84
04:38:05.880 0 04:38:06.004 14.84
04:38:06.145 0 04:38:06.270 14.84
04:38:06.472 0 04:38:06.597 14.84
04:38:06.769 0 04:38:06.894 14.84
04:38:07.174 0 04:38:07.299 14.84
04:38:07.486 0 04:38:07.611 14.84
04:38:07.798 0 04:38:08.048 19.14
04:38:08.220 2235.44 04:38:08.313 33.59
04:38:08.469 2268.24 04:38:08.563 33.59
04:38:08.688 2267.68 04:38:08.797 33.59
04:38:08.984 2268.24 04:38:09.093 33.59
04:38:09.218 2267.68 04:38:09.327 33.59
04:38:09.655 2268.81 04:38:09.764 33.59
04:38:10.014 2268.81 04:38:10.107 33.59
04:38:10.232 2268.81 04:38:10.341 33.59
04:38:10.497 2268.81 04:38:10.591 33.59
04:38:10.731 2268.81 04:38:10.840 33.59
04:38:10.981 2268.81 04:38:11.090 33.59
04:38:11.246 2268.81 04:38:11.355 33.59
04:38:11.480 2268.81 04:38:11.589 33.59
04:38:11.714 2268.81 04:38:11.823 33.59
04:38:11.964 2268.81 04:38:12.073 33.59
04:38:12.229 2268.81 04:38:12.338 33.59
04:38:12.478 2268.81 04:38:12.588 33.59
04:38:12.712 2268.81 04:38:12.822 33.59
04:38:12.978 2268.81 04:38:13.071 33.59
04:38:13.196 2268.81 04:38:13.290 33.59
04:38:13.430 2268.81 04:38:13.539 33.2
04:38:13.664 1648.3 04:38:13.773 15.62
04:38:13.898 740.43 04:38:14.007 14.84
04:38:14.148 735.34 04:38:14.241 14.84
04:38:14.382 735.34 04:38:14.491 14.84
04:38:14.834 734.21 04:38:14.974 14.84
04:38:15.130 734.78 04:38:15.224 14.84
04:38:15.380 733.64 04:38:15.474 14.84
04:38:15.614 733.64 04:38:15.708 14.84
And a run from ~60 - ~80 mph. "Vehicle speed" doesn't record, but I got RPM
Time ICP ICP (%) ICP V RPM (RPM) [0.0 - 8000.0]
05:22:50.301 0.3
05:22:50.442 892.03 15.23 1.18 2109.3
05:22:50.988 879.58 14.84 1.27 2105.3
05:22:51.721 2051.04 32.81 2.73 2120.3
05:22:52.329 2038.59 34.37 2.65 2156.3
05:22:52.891 1915.85 35.54 2.35 2185
05:22:53.421 1934.51 36.72 2.32 2204.3
05:22:53.967 1920.37 37.89 2.71 2234.3
05:22:54.513 1939.04 39.45 2.59 2265
05:22:55.059 1981.46 40.62 2.46 2287
05:22:55.605 1991.64 41.79 2.4 2332.5
05:22:56.151 1993.34 42.97 2.68 2339.3
05:22:56.869 2005.22 44.14 2.77 2369.8
05:22:57.477 2003.52 45.31 2.44 2406.3
05:22:58.023 2007.48 46.48 2.74 2429.3
05:22:58.554 2024.45 47.26 2.51 2456.5
05:22:59.115 1999.56 48.43 2.78 2454.8
05:22:59.661 1996.73 49.61 2.73 2499.8
05:23:00.207 2012.01 50.39 2.49 2513
05:23:00.753 2007.48 51.56 2.52 2550.3
05:23:01.284 2032.37 52.34 2.54 2538.3
05:23:02.032 2090.07 52.73 3.73 2590.5
05:23:02.625 3163.66 27.73 2.64 2507.3
05:23:03.171 1970.15 23.83 2.39 2530.5
05:23:03.717 1698.07 21.09 2.13 2507.3
05:23:04.248 1527.81 18.75 1.95 2482.5
05:23:04.778 1381.88 17.19 1.79 2456.5
05:23:05.308 1267.61 16.01 1.68 2438.3
05:23:05.870 1175.98 14.84 1.59 2411.5
05:23:06.416 1115.46 14.06 1.52 2392.3
05:23:07.134 1044.18 13.28 1.44
post #5 of 9 Old 04-23-2014, 04:18 PM Thread Starter
Sorry the formatting is so bad
I've tried multiple ways to get it to look nicer, but it appears an attachment is the only way. Let me know if you would like me to do that.
Thanks,
post #6 of 9 Old 04-23-2014, 06:46 PM
i have a 2000 7.3 and my truck had a long crank. i put a new starter on it now it starts as soon as i hit the key.
Mr. Stroke
willisville1@gmail.com is offline
post #7 of 9 Old 08-31-2014, 09:27 PM
Was there a resolution to this? I am having similar issues, did you replace the starter like willisville1?
1997 CCLB, 7.3 PSD, auto, 4x4, K&N intake, 4" exhaust from downpipe, 266k.
MNJohn33 is offline
post #8 of 9 Old 09-01-2014, 04:02 PM Thread Starter
My battery was good, my starter was fine. My truck had been sitting (in an heated shop) most of the winter with only an occasional start to move it out of the way. After a couple longer trips, the problem resolved itself. I think the HP oil system lost a little oil. After starting and running a few times it starts just as well as my other 99 Powerstroke. I do continue to have a problem that may or may not be related to the HPOP.
post #9 of 9 Old 09-01-2014, 05:30 PM
Thanks for the reply, it's nice when there's a happy ending to an older unresolved thread.
MNJohn33 is offline
