clutch replaced now leaks oil? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-22-2014, 12:39 PM Thread Starter
some say you have to tighten the flywheel to specs or it will leak oil?
it started about a week later?
is it the rms or can it come from somewhere else through the bellhousing?
thanks steve
ffsteve is offline
post #2 of 2 Old 04-24-2014, 07:34 AM
timmyboy76's Avatar
ya, theres a drain hole atop the motor, in the p/s valley, in the corner. ifoils' leaking in the valley, it'll drain down the hole, into the bell housing, replicating a bad rear main seal.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
