2001 f250 with 7.3l powerstroke won't start - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-21-2014, 07:45 PM Thread Starter
Question 2001 f250 with 7.3l powerstroke won't start
I have a 2001 f250 with a 7.3l powerstroke. The problem started off going down the road it started hesitating then it stalled. I replaced the composition sensor. After a lot of cranking it finally restarted. For a while I could get it to restart and it would run for about 5 to 15 minutes in the drive way if I tries to put it in gear it would stall. If you held your foot on the gas you could keep it running a little longer, but it would still eventually stall. The more you tried to start it the longer it would take to restart and eventually it wouldn't start at all. Currently it will not start at all. I have gotten the codes p1670,and p1219 are the most consistent. I also have code B1359. I also had codes p1294, p1271, p1277, but I just replaced the valve cover gasket and under valve cover harness. now these codes seem to have gone away, but it still won't start. I have the valve covers off right now when I crank the engine over no oil shoots out of the injectors. I have replaced the CPS twice, PCM, IDM, ICP, valve cover gasket twice, all of the injector O-rings, at least 3 of the injectors had bad O-rings. I have checked the fuses under the dash, and under the hood. I have the wire harness currently torn apart and can't find any damaged wires. I am getting 2400psi of hpop, my ipr duty cycle starts at 14.84 and goes up to 48. I'm getting 150 to 160 rpm while cranking. my batteries have been tested at both autozone, and napa both were good.
darea is offline
post #2 of 7 Old 04-21-2014, 08:01 PM
sbluke55's Avatar
Quoted: 624 Post(s)
Garage
I believe it is not cranking fast enough to start. How are your battery cables? Are they corroded? Are they stock? Is it the stock starter. Are your terminals clean.
Edit. I checked the codes first two codes and it could be bad idm, idm relay or fuse, or idm wiring from PCM. Hope this helps.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 7 Old 04-24-2014, 05:20 PM Thread Starter
thank you for the help I figured it out. The last composition sensor I purchased came with shims, and I used them. I took them out and it started.
darea is offline
post #4 of 7 Old 04-24-2014, 05:52 PM
timmyboy76's Avatar
what sensor?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 7 Old 04-24-2014, 05:55 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Cam position
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #6 of 7 Old 04-24-2014, 07:11 PM Thread Starter
cam position sensor
darea is offline
post #7 of 7 Old 04-25-2014, 04:00 PM
timmyboy76's Avatar
might wanna check to make sure its not rub'n against the gear, with no shims
