Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 12-12-2008, 11:16 AM
jking2986 jking2986 is offline
Unhappy New Motor????
I just had my turbo replaced on my 01 F350, and I took my truck into the local ford dealer and they said I need a new motor. My truck was idling rough and smoking white smoke. They said the turbo I had just replaced was bad. only getting 11psi max boost. And they said the #6 and #8 cylinders were only getting about 120 psi. I dont know a whole lot about these motors, but I would think it could be fixed? He said with 161,000 on it it wasnt worth trying to fix. But I would rather try to fix it than spend $12,300 on a reman. The truck is in the shop now getting the turbo re-replaced under warranty.The guy wasn't much help but I would hope I would have some other options besides a whole new motor?
Old 12-12-2008, 11:23 AM
Powerstroke W/smoke Powerstroke W/smoke is offline
wow. good luck buddy. i'm sure if you have to do a motor you can find one for a lot cheaper than 12k. good luck bud
Old 12-12-2008, 11:38 AM
troid123 troid123 is offline
Send a message via AIM to troid123
just go buy a new truck...
Old 12-12-2008, 11:46 AM
Marty Marty is offline
International Threat
Where are you located?
With 161k miles that thing SHOULD be just getting broken in. Tell that idiot who told you that you'll be taking your business elsewhere.
Old 12-12-2008, 11:57 AM
00 stroker 00 stroker is offline
look on ebay and see whats in your area
Old 12-12-2008, 12:00 PM
here's my thread about my motor swap.
From broken to smokin'
Old 12-12-2008, 01:56 PM
That's what I hoped. I just bought it last year with 123k on it because I thought I would get 250+ out of it
Old 12-12-2008, 01:59 PM
Just because I'm not getting enough compression in 2 cylinders, I wouldn't think that would be the end for that motor?
Old 12-12-2008, 03:40 PM
DAYTONA392005 DAYTONA392005 is offline
Mine is a 2000 and it has 311,000 and still strokin strong.I'm expecting another 200,000 or so.
Old 12-12-2008, 03:44 PM
thesmokinstroke02 thesmokinstroke02 is offline
if you do have to do a swap put a CR cummins in it
