01 7.3 excursion white smoke, rough idle, takes awhile to start - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-19-2014, 04:41 PM Thread Starter
Hey guys I have an 01 excursion. Drove it home from pa and it died on me
Towed it to a diesel shop and had them check it out.
I had a bad icp and 3 bad injectors and two bad high pressure oil lines. And a bad icp
Well the quote was ridiculous so I fixed the injectors myself
Let me give a little background
I just bought the truck that's why I went to pa. The truck had a light miss and pours white smoke. Whether hot or cold. It does not smell like oil. Takes it about 10 seconds of cranking to start.
I replaced the injectors and the icp and pigtail. Still have the white smoke and a light miss
I have a few codes
Engine off.
P1271
P0237
P0470
On
P1211
P0476
P0452
Ebp 6.3 psi
Ipr 5-10 idle
21 2500 rpms
I have a pretty nice scanner so I can get some info. I assume the ebp codes is the tube being clogged from what I read.
Any help I would greatly appreciate
95e350 is offline
post #2 of 2 Old 04-20-2014, 11:39 AM Thread Starter
Well I started doing so more diagnosing and one of the new injectors wasn't firing. So I swapped cylinders and same thing. So I am now lookin into replacing the wiring harness
95e350 is offline
