Cannot get AE to connect to my truck! Cranks and runs rough but can't pull codes - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-19-2014, 01:39 PM Thread Starter
jshalala's Avatar
2001 Ford F350 with the 7.3.
Recently replaced all 8 glowplugs and relay.
Had an issue with it starting cold so I replace the above parts, even after I replaced them it would still start hard. It cranks strong but does not fire until after a good amount of time cranking. It attempts to start then finally starts running but very rough.
Last week I replaced leaking hpop line o rings, and the truck started running better. Now its back to doing it again.
I pulled the ICP sensor and it was full of oil and kicked the SES light.
I ran a buzz test two days ago with AE. Now I cannot get AE to connect! I need to so scan the truck so I can see what my starting pressures are. I know it is a high pressure oil issue.
I have power to the cig lighter, I pulled all fuses and they are good. I plug the connector into the OBD port and it lights up but will not connect. I tried two different scanners.
What else could cause the scanner to not connect after it did a few days ago?
Does an unplugged ICP sensor cause it to not connect?
2003 Ford F250 6.0 powerstroke 4x4.
ZF6 manual trans, ext cab short bed
deleted, 4 inch exhaust, gauges, traction bars
16x10 Weld wheels wrapped in 33s
Early 1999 Ford F250 7.3 Powerstroke 4x4
Crew cab short bed
straight pipe, intake
jshalala is offline
post #2 of 9 Old 04-19-2014, 04:21 PM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
You get a WTS light when you first roll-on the key? (shows the PCM is running)
The unplugged ICP wouldn't have any effect on communication.
How does the OBD port look? No green pins?
Get it to run a bit if you can and go feel the exhaust manifolds to compare the heat in them to look for a dead side (don't need the AE for that )
You changed the configuration from OBD-II to J1850 PWM?
NoRalPh is offline
post #3 of 9 Old 04-19-2014, 04:31 PM Thread Starter
jshalala's Avatar
WTS light comes on.
OBD port looks fine.
I did not change any configuration on AE. It worked great two days ago!
Crew cab short bed
jshalala is offline
post #4 of 9 Old 04-19-2014, 05:12 PM
schlutzer's Avatar
Quoted: 18 Post(s)
You are definitely sure the cigarette lighter works? The one down by your heater controls not beside the airbag on/off switch?
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 9 Old 04-19-2014, 05:21 PM Thread Starter
jshalala's Avatar
I plugged a charger in it and the light was on.
No fuses blown
Crew cab short bed
jshalala is offline
post #6 of 9 Old 04-20-2014, 07:05 AM
Quoted: 133 Post(s)
What kind of charger?
You're not trying to power the computer you use the AE in from the cig ltr - are you?
If so, look for burned wires in the AE cable or USB end
NoRalPh is offline
post #7 of 9 Old 04-20-2014, 07:53 AM
Quoted: 28 Post(s)
You didn't put the charger to 24 volts did you?
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #8 of 9 Old 04-20-2014, 06:02 PM Thread Starter
jshalala's Avatar
The "Charger" I plugged in was just a cell phone charger.
I am going to double check AE works on my Excursion. If it works on that then I'll comb the truck over to see if I can find out what's going on.
This truck is driving my crazy lol
Crew cab short bed
jshalala is offline
post #9 of 9 Old 04-21-2014, 07:53 AM Thread Starter
jshalala's Avatar
Update: removed the programmer from the truck, checked PCM connections and rebooted AE on my computer. I was able to connect and scan the truck!
ICP pressures were at 725, with the sensor unplugged.
Tried to run a cylinder contribution test and it said not available, the truck might be running a grey CPS which I heard interferes with that test, Ill double check.
When I started it, it cranked for a decent amount of time without firing then instantly fired right up nice and smooth but with a puff of white smoke.
I am convinced it is a high pressure oil issue, it seems like it is cranking to build pressure then it finally fires.
What tests should I run to prove or disprove my theory?
Crew cab short bed
jshalala is offline
