e99 white smoke and rough idle on startup! - Ford Powerstroke Diesel Forum
post #1 of 21 Old 04-18-2014, 06:23 PM Thread Starter
Angry e99 white smoke and rough idle on startup!
new injectors 170/100 single shots, ts 6 position, cold air, 4" turbo back, new icp,new ipr, new uvc harnesses, uvc harness pigtails soddered into engine harness, new fuel pump, im sure im forgetting something. I didn't notice anything before my injector install because of the horrible running condition of the truck due to injectors but now when you start it on a 30 deg day or a 60 deg day first thing in the am it shakes bad and blowes white smoke. the other day I figured out instead of letting it work through this issue I decided to rev it to 1800rpm and it took seconds and it cleared right up and all I had was a light shimmy and the normal blue smoke till water temp. im really lost and the guy I got my injectors swears the injectors cant be bad (leaking down into the cyl over nite) im just looking for everyones 2 cents.
thankyou in advance
newcomer!
jacob00lehn is offline
post #2 of 21 Old 04-18-2014, 06:37 PM
Quoted: 27 Post(s)
Did you buy the injectors from an individual or company? TS chip reburned for single shots?
strokin-7.3 is offline
post #3 of 21 Old 04-18-2014, 06:46 PM Thread Starter
Thankyou for the reply. I'm new to the forum an I'm just looking for some help. I purchased the injectors through a local diesel shop who got them strait from ddp. The ts was sent to no limit tuning in ga and I told them what injectors were going in. After the truck builds oil and water temp it runs awsome. Just that initial startup in the am overnite.
post #4 of 21 Old 04-18-2014, 06:54 PM Thread Starter
Sorry I just re read what I typed. My injectors came from ffd
post #5 of 21 Old 04-18-2014, 07:03 PM
Quoted: 27 Post(s)
Is it hard to start or does it fire right up after the WTS light goes out?
post #6 of 21 Old 04-18-2014, 07:13 PM Thread Starter
Yes it will start right up just smokes and runs rough. If the block heater is plugged up it helps.
post #7 of 21 Old 04-18-2014, 07:17 PM
Quoted: 27 Post(s)
Check your glow plug system. GPR could be bad or possibly a bad glow plug or two. How many miles on truck?
post #8 of 21 Old 04-18-2014, 07:21 PM Thread Starter
204,000 brand new glow plug solinoid heavy duty one and it also has brand new diesel rx glow plugs.
post #9 of 21 Old 04-18-2014, 07:35 PM
Quoted: 27 Post(s)
how long was the heater plugged up and was it the same or just less noticeable but still there
post #10 of 21 Old 04-18-2014, 07:38 PM Thread Starter
If it's between 35 and 50 degrees it just makes it a little better. If it's between 50 and 70 deg and the block heater is plugged in the glow plugs don't cycle and it fires right up no smoke at all and no missing at all.
