15lbs ICP - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-18-2014, 12:06 PM Thread Starter
15lbs ICP
Got my autoenginuty hooked up and showing 15lbs ICP. Takes about 500 to start one I believe. Any ideas on what causes this?
15lbs< Not a typo. Got about %65 duty cycle while cranking.
2000 f250 crew cab, 7.3 auto, 250/200cc hybrids from Swamps, Swamps tunes, 38r turbo, ARP head studs, Comp springs, Riffraff boots, cold air, 5 inch exhaust, 3 inch lift.
wiley79 is offline
post #2 of 10 Old 04-18-2014, 12:33 PM
Quoted: 5 Post(s)
Problem is.. if you only had 15psi of ICP, then IPR would be maxed out at 85%.
So something in the data is incorrect.
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #3 of 10 Old 04-18-2014, 12:40 PM
Quoted: 728 Post(s)
15psi means your only showing residual pressure from the lpop. You ipr is stuck and dumping all pressure back to the pan. Pull it out take it apart and clean it, reinstall.
Corey@CNCFAB is offline
The Following User Says Thank You to Corey@CNCFAB For This Useful Post:
wiley79 (04-18-2014)
post #4 of 10 Old 04-18-2014, 03:58 PM Thread Starter
My IPR has 230,000 on it, would it be best just to replace? Or do they not go bad?
wiley79 is offline
post #5 of 10 Old 04-18-2014, 05:27 PM
Quoted: 728 Post(s)
They do go bad. You can test it by unplugging it and running jumper wires to at least make sure the coil works, but that doesn't necessarily mean the spool inside is moving correct.
post #6 of 10 Old 04-19-2014, 04:52 AM Thread Starter
Went out this morning while its cold, 40 degree's or so, and I had 26lbs of pressure at 68% duty cycle.
Something just aint right. ICP first then maybe a HPOP?
wiley79 is offline
post #7 of 10 Old 04-19-2014, 04:54 AM
Quoted: 728 Post(s)
Hpop highly doubt it. Unhook your icp then try to start. Ipr is probably stuck or bad.
wiley79 (04-19-2014)
post #8 of 10 Old 04-19-2014, 06:00 AM Thread Starter
I unhooked it, then I also replaced the ICP last week along with the cam sensor. No start. Just ordered a new IPR, I gotta be getting close, LOL.
wiley79 is offline
The Following User Says Thank You to wiley79 For This Useful Post:
Corey@CNCFAB (04-19-2014)
post #9 of 10 Old 04-19-2014, 06:16 AM
Quoted: 728 Post(s)
Thats why I keep an extra on hand. I put a brand new one in mine on my rebuild and stuck after 200miles. Just needed cleaned. Debris from having everything opened up. Stuck old one back in, fired right up.
post #10 of 10 Old 04-19-2014, 08:01 AM Thread Starter
Thank you sir. Should have a new one here in a few, I'll let ya know.
wiley79 is offline
