Eating oil, smokes, everything is wrong with this truck. - Ford Powerstroke Diesel Forum
post #1 of 31 Old 04-14-2014, 01:23 PM Thread Starter
I recently purchased this truck, 1999 250 powerstoke 225k. Purchased it using oil and had oil in fuel so I changed injector o rings, 2 were ate-up, thought I cured it.
Now first long drive after o-rings (15 miles in traffic running for 45 min) and its out of oil again!!
Before the trip I had a hard time starting and I am pretty sure the fuel screens in the tank are clogged up as I have to give it throttle for it to stay running for the first few minutes then idled fine when warm but it was smoking more than normal. It was smoking white at idle and dark smoke (blue black idk) on harder acceleration, not to much that I was concerned to drive it. It was sluggish to accelerate, and the turbo noise sounded different.
The truck is still parked 15 miles away or I would do some more looking around on it. Maybe turbo oil seal related? I will look in the coolant tank for oil and see if the turbo wheel has any play. I hope its not piston rings but could it burn 3 gallons of oil that quick?
There was a little oil in the intercooler piping when I had them off for o-rings.
Early 99 7.3
MikeyKC is offline
post #2 of 31 Old 04-14-2014, 01:54 PM
Quoted: 5 Post(s)
Did you change all the O-rings on every injector?
Is there oil in the fuel again?
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 31 Old 04-14-2014, 02:10 PM Thread Starter
I did all 8. I had trouble getting 2 injectors in and hope I didnt rip them or something.
I did not empty the tank, so I cannot tell. I was going to run it empty first then fill it as I had half a tank.
Early 99 7.3
MikeyKC is offline
post #4 of 31 Old 04-14-2014, 02:23 PM
Quoted: 5 Post(s)
I've heard of people nicking O-rings on reinstall.
ianstew is offline
The Following User Says Thank You to ianstew For This Useful Post:
Corey@CNCFAB (04-14-2014)
post #5 of 31 Old 04-14-2014, 03:38 PM Thread Starter
but how would you explain the smoke? it didnt smoke before when the orings were leaking?
smoke would be air/fuel ratio related??
Early 99 7.3
MikeyKC is offline
post #6 of 31 Old 04-14-2014, 05:13 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
What kinda blow by are you getting? Hopefully you don't have a cracked piston, or a hole in one 😭😭😫😫😁😁
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #7 of 31 Old 04-14-2014, 06:17 PM Thread Starter
It wasnt too bad had some, I did not check when it was smoking. Im going to go bring 3 gallons of oil and hopefully bring it home tomorrow. I will tell you then.
How do I do a compression test on this thing? and is there a way to test the turbo?
Early 99 7.3
MikeyKC is offline
post #8 of 31 Old 04-14-2014, 07:07 PM
Winning DUHHH
Quoted: 8 Post(s)
You have to pull the glow plugs under the valve covers and thread in the adapter. And test turbo? Meaning?
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
post #9 of 31 Old 04-14-2014, 07:48 PM Thread Starter
I read another thread saying slow acceleration and smoke could be turbo related.
Early 99 7.3
MikeyKC is offline
post #10 of 31 Old 04-15-2014, 07:48 AM
timmyboy76's Avatar
3gal lost, i'd think the truck wouldn't run. The truck will shut off after a certain loss of oil.
a grease-gun hose will thread into the gp hole, for comp testing. Is the exhaust wet with oil? Remove the compressor housing and check play in turbo.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
