Replacing Radiator what to do... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-13-2014, 11:00 PM Thread Starter
I am debating purchasing a new oem radiator or possibly the aftermarket mishimoto to never deal with problems but the radiator guy says the all aluminum ones have there issues also.
I am losing coolant. Ther e is a couple inches left on the degas bottle and somewhat holding (probably because of the mass amount of coolant at that level. Not sure where I am losing but during my last inspection it looked like at the bond between the plastic and aluminum on the radiator it was leaking because I could see coolant in that area. It could also be loosing some pressure at the thermostat housing (upgraded to billet with new oring) but I doubt a tiny leak that doesnít show much anything is cause off losing so much quickly. I have NOT verified that the problem is at the radiator but I used the pressure test tool and the pressure dropped quick. It is currently blizzard snow where I live so I am going to wait until the weather calms down and spray for bubbles at the suspect location.
Another option is for me to recrimp but I figured it would just leak again sometime soon and I am a little scared to trust me on that one. Taking it into a shop is a little out of the question because the nearest big city is one hour away and I donít have a second vehicle so taking it out and driving it in is not gonna happen especially with the risks. If I have them pull it there it will be 250 for pulling and putting it back in, at that point they would have to order a new one or repair if order a new one I would have to have them pull it again so I am best off ordering oem or mishimoto.
What are your thoughts on going with one or the other?? I plan on keeping my truck for a while but am also tired of working on it so might be paying for service more in the future which could lead me to sell it.
Thanks.
bskier is offline
post #2 of 5 Old 04-15-2014, 08:47 PM Thread Starter
So, I checked out the leak tonight. It was leaking around the top large radiator flange that connected to the house. Two spots around the hose to plastic neck mating and one a couple inches away (tried my hardest to make sure it wasn’t coming from a trajectory around the hose because that is fixable. Anyways I think it lived its life. I am not going with just a new top plastic piece. So there is not a clear winner in this situation. Yea OEM made it this far but lets face it we don’t want the plastic down there especially with such a large mating surface. Mishimoto is not worth the dollars. This other brand/brands from Rockauto seem to be poorly shipped and probably have there own problems. I guess I am going to look at what’s around and decide soon.
Good news is this thing has been running and even a little bit hard today and not a phase in coolant or oil temp. Overkill cooling system.
bskier is offline
post #3 of 5 Old 04-15-2014, 08:55 PM Thread Starter
All of rockauto's radiators have plastic, most top and bottom..
bskier is offline
post #4 of 5 Old 04-16-2014, 06:37 AM
timmyboy76's Avatar
here's an all aluminum...
2 Row w O EOC w TOC High Performance All Aluminum Radiator for 7 3 V8 Diesel At | eBay
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
The Following User Says Thank You to timmyboy76 For This Useful Post:
bskier (04-17-2014)
post #5 of 5 Old 04-17-2014, 09:01 PM Thread Starter
I went ahead and purchased the mishimoto, found a really good deal.
My next thing I am contemplating is not replumb the transmission lines into the radiator. My opinion is the less hoses and connections less places for failures (reason I would never install a hpx). I don’t think I need the heat loss since when I pull 8k+ trailer up some of the big Colorado passes in summer it never gets above 165 (thanks to the 31 row 6.0 intercooler). I figured the benefit that radiator adds is might be to warm up the transmission on colder days when I have it plugged in (I used to have a heater pad on the transmission pan). As weird as it sounds I also think the front end might benefit from the weight reduction of not using that area. Any thoughts?
bskier is offline
